The cordless drills I have purchased even good ones like Ryobi lasted about three years The drills will work good but the batteries go dead after a while. My Ryobi I keep one battery charging in my charger all the time but before you do this check your manual to make sure its ok. I change batteries every two weeks when not in use all the time. I never have a run down battery that way.
SOURCE: Craftman model#973.113050 drill/driver. Lost
Batteries do go bad. They sorta die on an age and number of charges basis. I have several sets of DeWalt 18 volt tools. Comes to a total of 8 batteries. I always write the date purchased on the battery. Well, since last December both of my 2006 batteries went bad. I expect the 2007 batteries will go bad this year sometime.
With the NiCad batteries, they are good for a certain number of charges. Which is one reason to run the battery down till it begins to affect performance of the tool. Don't "top off' the charge by putting a battery that is not worn down in a charger, cause you effectively use up one more charge.
I have never had batteries last much more than 2 and a half years.
Now, the Lithium batteries are supposed to have fixed all that --
SOURCE: my 16.8v screwdriver's battery is showing me a
i am not conversant with crafsman, but on most chargers if both are flashing together it generaly means the battery is cactusfuckti
