Door is closed but I get door is open error
Ensure all such door(s) are shut by opening them, and closing them.
If that fails, then locate the sensor and blow on it. Paper-dust can built-up and interfere with them.
If still no-joy, then that error could also mean that a sheet, (or a piece,) of paper is still in the print-path and must be cleared first.
SOURCE: Savin 4090 error code
check this link, look under error codes
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
SOURCE: Toshiba e 350 "close finisher door"
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
SOURCE: service code 990 savin 2545 copier
If changing
the cylinder, developer and blade the problem is not solved, proves to resetear
software pressing by more than 10 seconds the point (.) and the numeral (#)
both simultaneously, until it is extinguished and it returned to ignite the
machine, this resetea software. If the problem persists, then the problem can
be in the hard disk, replaces hard Disk.
Si cambiando el cilindro, revelador y cuchilla no se soluciona
el problema, prueba resetear el software presionando por más de 10 segundos el
punto (.) y el numeral (#) los dos a la vez, hasta que se apague y vuelva a
encender la máquina, esto resetea el software. Si persiste el problema,
entonces el problema puede estar en el disco duro, reemplace el Disco duro.
SOURCE: Functional error SC542
This is a fuser temperature heating error.
the fuser has not heated up within 5 minutes after switching the copier on.
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Bad connection to fuser unit
You will need a service technician to fix this.
Testimonial: "Very quick and helpful reponse. Thanks!"
SOURCE: Savin Copier 2020, IP 192.168.2.100 functional error SC672
yes a 672 is an address book error. do you have scanner feature on this machine?. it may be bad. you may need a tech to come remove the option. turn the machine on and use it as a copier. then reinstall the option and see if the error returns. it could be a static build up or the option is bad.
