SOURCE: sa-ht545 error code f61- comes
F61 just equal 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic IC 502.
As both said ICs get very got first remove bottom steel grill and with the power off and capacitors drained (shorted together with a low ohms resistor or leave unit powered down for a few hours) resolder the ICs legs if there are any signs of cracks aka dry solder joints.
Hope that helps.......
SOURCE: hi ther i have a
THE F61 ERROR USUALLY MEANS A FAULTY FAN,BUT IT SOMETIMES CAN BE FIX JUST BY GIVING THE FANS A GOOD CLEANING.
