Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Apr 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nf error cycle won't finish-maytag neptune TL
I cannot do a load of laundry. I keep getting the nf error at 13 minutes and it will not finish. What can I do?
Anonymous
Level 2:
  • Expert 335 Answers
  • Posted on Apr 21, 2009
Anonymous
Expert
Level 2:
Answers
335
Questions
0
Helped
197869
Points
881
NF = No water fill. I haven’t had this failure to date but this how I would troubleshoot. Could be a block at the water valve inlet screens where the supply hoses connect to the machine. Check to see if the washer fill screens are blocked, It could be a failure of the Cold/Hot water solenoid valves. I would try to fill with hot water if no fill try cold only.
It might be easier to go into Service Mode to turn on and off the water valves while troubleshooting this issue. Enter Service Mode and use the keys assigned to the table at the bottom right side of page 16 of the FAV6800A/9800A Service Manual . Do this check only if you feel qualified, if still no water fill after the above checks I would break out my DVM and check for 120VAC at the water inlet valves. Post Back if you need additional help. Rich
NF code may tag neptune front loader!
www.fixya.com > ... > Neptune > Maytag Neptune MAH5500B Front Load Washer
Apr 14, 2009 - CODE IN MAYTAG WASHING MACHINE Hello & Welcome to FixYa NF error in yourMaytag is displayed due to no fill condition, when the washer tries to fill but ... SOLVED: Maytag Neptune MAH6500AWW '03 front ...
Nov 9, 2016
SOLVED: HOW TO FIX NF CODE IN MAYTAG ...
Oct 2, 2011
SOLVED: Machine is flashing nF code
Jul 13, 2011
Maytag Neptune MAH9700 Front Load Washer Nf code ...
Jun 21, 2011
More results from www.fixya.com
Getting nf from maytag neptune tl washer code
Don't know unit but see if you can get wiring diagram and see where the relay that picks up that cycle. You can just tap them at times to get them to work. Hopefully it doesn't have optic couplers (no relays) cause the that board is bad
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
It stops about 13 minutes from the end of the cycle, right before it spins. It displays NF.
""It stops about 13 minutes from the end of the cycle, right before it spins. ""
NF is no fill for the FAV6800A and FAV9800A are you still having the issue.
To me it sounds like you have two issues
""It stops about 13 minutes from the end of the cycle, right before it spins. "" with no additional info this could be a issue with the Clutch Pulley. Did you take any error codes like DC or UC?
Are you going to DIY the fix or call in a repair service?
3helpful
2answers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
My maytag neptune TL when it gets down to 12 minutes left it starts flashing dc and wont finish the cycle, what is wrong?
You could have a Clutch malfunction if the machine is a FAV6800A or FAV9800A. If that is you r machine type see this post. Clutch Fix
Post back of you have questions.....Rich
Neptune TL, stops at the 11 minutes to end and will not go past, I have to shut off, hit spin cycle to finish load
Hello krabby64
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
21helpful
5answers
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
