That really doesn't help out at all give me a Manufacture Name and the Model Number of that juicer normally you can find it on the bottom or the side of the juicer.
check the voltage for the unit and if is as what you have then take it back for exchange or refund as it is not fit for the purpose and will be under warranty.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
Hi You can easily register your Philips Juicer online by visiting the Philips support site and creating a Club Philips account.You need to create an account to register your product.This is for easy support on your product from the Philips Company.
my jack la laine power juicer stopped and won't start again...i have used it less than a dozen times over the past 8 months. is there a restart button? anybody have this problem or do I have to send it in and pay $30.00 just for shipping and handling on that so-called 'warranty'?
Yes for the PHILIPS HL-2051 juicer the screen comes off very easily if you know how to do it as I figured it out without the manual. My method works 100% guaranteed. What you do is unplug the cord from power receptacle. Take the whole PHILIPS JUICER unit/contraption and put it between both of your knees/legs to support it without your hands. You then use both free hands to pull on the loose fitting housing which collects the juice and VOILA the top loose housing and the screen comes of very easily because it is only a friction fit tightness that the screen sits on the base motor. It is then very easy to put back on again after cleaning.
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
