Question about Kyocera Mita Fs-1016 Mfp Multifunction; Printer / Copier / Scanner. Meter 35,970
BONJOUR JAI UNE PHOTOCOPIE KYOCERA 1016MFP ELLE INDIQUE LERROR 6400 COMMENT FAIRE POUR RESOUDRE LE PROBLAIME
    New Friend:
  • 3 Answers
Mettez le au soleil
Posted on Oct 19, 2013
4 Suggested Answers
Anonymous
SOURCE:
Nikolay Boychev
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
Nikolay Boychev
  • 525 Answers
SOURCE: how can I resolve kyocera
Causes:
Follow the flow chart:
Turn power switch off, and
remove power cord.
Detach YC7 connector on
the engine/high voltage
PWB.
Measure resistance
between pins 1 and 2 of
the detached connector.
Open
(infinite)?
Yes ---> Replace the fuser thermistor.
NO ----> Detach YC1 connector on the power source PWB.
Measure resistance
Open
(infinite)?
Yes ---> Replace the thermal cutout or heater lamp.
NO ----> Replace the engine/high voltage PWB.
Mike
  • 167 Answers
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Posted on Dec 13, 2011
Quelle sont les etapes que la manette universel fontione
Lorsque vous souhaitez programmer un dispositif trouver le premier code.
Ensuite, appuyez et relâchez le bouton que vous souhaitez attribuer le code,
Ensuite, appuyez et maintenez enfoncé le bouton SETUP jusqu'à ce qu'elle occupe une lueur.
touché les numéros de code. il devrait clignoter deux fois, en indiquant un code de bonnes.
puis cliquez sur le bouton que vous venez de configuration, et le diriger vers le périphérique, et cliquez sur le bouton d'alimentation.
Si elle vient, vous avez choisi le bon code
Il ya généralement plusieurs codes pour une marque, afin de les essayer tous, un par un jusqu'à ce que vous avez.
Répétez la procédure pour d'autres articles. Soyez sûr d'assigner une touche différente et appropriée labeld.
Aug 31, 2011 | One For All URC4110 Remote Control
BONJOUR JE POSSEDE UNE IMPRIMANTE LASER COULEUR SAMSUNG ELLE NE FONCTIONNE PLUS ET AFFICHE UN MESSAGE D ERREUR SYSTEM ERROR CYCLE POWER QUE PUIS JE FAIRE
Bonjour cevale358 ,
Il n' y a malheureusement pas d' autre solution que de rentrer l' imprimante chez Samsung pour r?paration . Il s' agirait malheureusement d' une panne assez courante sur ce mod?le qui concerne le fusible et l' unit? d' alimantation .. Voici quelques pr?cisions si tu comprends l' anglais ... http://www.fixyourownprinter.com/forums/printer/66821
Cordialement ,
fanaudi .
Aug 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
Bonjour, mon problème c'est avec une
j'aurai besoin d'un peu plus d'info sur model de camera,et ce que vous tenter de faire
si la camera est debrancher de l'ordi ,et si l'ordi demarre normalement sans la camera,
vous pouver me contacter par email (aselectronique1@gmail.com.
ainsi on pourra peut-etre trouver une solution je ne comprend pas les #232, 233
merci sicerement alain.
Jan 01, 2011 | Canon Video Cameras
Comment proceder pour creer un site twittter
Bonjour, Allez sur le site de twitter: http://twitter.com/ Cliquez sur le bouton jaune a droite: Sign Up Et rentrez vos information comme indique sur la page puis suivez les instructions. Une fois que vous avez cree votre compte vous pouvez commencer a "twitter" en rentrant ce que vous voulez ecrire dans le champ en haut de la page:
Plus de details: http://www.commentcamarche.net/faq/18775-comment-utiliser-twitter
Amusez-vous bien!
Oct 20, 2010 | Twitter Computers & Internet
Bonjour, j'ai un problème avec ma MP600. Elle n'imprime plus en noir. Pourtant lorsque je lance une impression noir et blanc elle fonctionne comme si elle imprimait, mais à la sortie, la feuille...
English to French translation bonjour il se pourrait que votre t?te sur votre imprimante est bloqu? aller ? la maintenance de votre imprimante et faire le nettoyage de vos t?tes dans la partie maintenance de votre imprimante, il vous dira everthing comment le faire
Oct 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I want the eurovox codes for 5a01 ....can any1 plzz help????
bonjour jaimerais bien savoir jai un viewsat 2000 ultra et jai fait mes mise a jour et jai les poste de radio et de chaine sauf il m afiche le signe $ et crypter et jai une coupole de bel allor comment avoir une cle ou un code pour avoir les chaine merci beaucoup et je vais attendre votre reponse ah aussi pourier vous me l ecrire en francais car je ne lie pas en anglais
Apr 10, 2010 | Audio Players & Recorders
Creative labs webcam fonctionne t elle avec vista?
Bonjour, avez vous regardez ici ?
http://support.creative.com/Products/Products.aspx?catid=218
Oct 03, 2009 | Creative Labs Creative Webcam
Help me
le message "sa manque fichier usb.sys" vous indique que Windows est defectueux, vous devez reinstaller Windows.
ici il est explique' comment reinstaller ou reparer Windows(reparation, mise a jour de version ou mise a niveau):
Comment faire pour installer plusieurs mises à jour ou correctifs .
Réparer Windows XP - La solution
Windows XP - Installation et mise à jour
Nov 05, 2008 | Microsoft Computers & Internet
Kyocera Mita Fs-1016 Mfp Multifunction; Printer / Copier / Scanner. Meter 35,970 Logo
192 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
