The disposal was first jamed but released with the tool and reset the disposal.. The chamber is free to rotateThe disposal was first jamed but released with the tool and reset the disposal.. The chamber is free to rotate
You can't post conmments that contain an email address.
with the power "off", check inside the unit to make sure nothing is jammed in there. assuming the interior is clear, try the reset button which is usually located on the bottom of the unit. may need to use a mirror and a flashlight to locate it. if the unit hums (indicating power is there) but it does not rotate/turn/work, use your "disposal key" or a hex wrench to turn it manually: usually inserts on the bottom-middle of the unit; turn it both ways to free it up.
Push reset button located bottom of disposal? Use broom stick and rotate stuck cutter disk? Copy following link to troubleshoot by type of problem: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html Titan appears to be repackaged sinkmaster garbage disposal. There is no service manual or installation manual on brief web search. However link above has manuals sinkmaster and other brands . Add a comment and say what you discover
