SanDisk Sansa e250 MP3 Player Logo
Anonymous Posted on Sep 23, 2007
Rockbox now wen i turn it on some wierd rockbox thing comes up instead of the usual cycling between the animated pictures (camera, music, etc.). so what i did was i went on my computer and deleted the rockbox thing and now when i turn on the sansa it says cannot find rockbox and then shuts off so then i went to the rockbox website and downloaded a zipped sansa rockbox file and i unzipped it and put it in the sansa folder. but now when i turn it on it still says cannot find rockbox so my 2 questions are how can i get rockbox back and also how do i get it back to the normal screen instead of the rockbox screen??????
Anonymous
Level 3:
President:
  • Master 1,285 Answers
  • Posted on Apr 16, 2009
Anonymous
Master
Level 3:
President:
Answers
1285
Questions
Helped
296745
Points
3126
1 - since you really did nt delete all of rockbox (you shoud reinstall the whole thing) this will take of the system looking for it.
2 - you will have a dual boot up and a choice of which one u wish
Key Action
Power Start Rockbox
Long Power Shutdown Rockbox
On shutdown, Rockbox automatically saves its settings.
Rockbox has a dual-boot feature. To boot into the original firmware, press and hold the Left button while turning on the player.
feel free to rate the help
A
Anonymous
Go to bootloader and folloew instructions
4helpful
2answers
How do i get my sansa to read my micro sd memory card
You can only have music on the microSD card; no pictures and no videos. The music tracks need to be in a folder titled "MUSIC".
30g ipod rockbox wont sync with itunes after doom install
If you look at the Rockbox documentation, there is a way to reboot your iPod into the original iPod firmware and use the original interface as well as having the ability to boot into the Rockbox firmware.
The Rockbox firmware is great if you want more options for transfer and skins and so on, but it is not as easy to use as the stock iPod interface.
You can also refer to the documentation that will show how to remove Rockbox and go back to the original Apple software. I ran Rockbox for a while but it was more or a pain in the **** than I cared to deal with so I uninstalled it.
Worst case is you can do a full restore in iTunes that will restore the iPod to factory, but it will wipe the music you have loaded. Hope you have a backup.
Hope this helps.
Cheers
Camera taking wierd pictures
look for the reset to factory settings for your casio. i could also be the settings have been changed so more light is coming in the camera which explains your bright pictures. but the lines across ALL the pictures warn something of a CCD/Cmos sensor problem.
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
SPH-P207 Camera Problems
when it "freezes" it's usually just taken a picture (easy to accidentally press the shutter) and is showing it to you--press save (left function) or erase (right) then is ready for another--can tell because the picture is moving as you move the phone
Sansa 250
okey this sounds ... wierd... you uppgraded it? did it get bad tracks when you putted the tracks in or did it take a time..
your songs maby aren´t in rigth .... are you using mp3\wma songs look so they aren´t any other... well if it don´t helps you you can do 2 things leave it back to store and get help there or try rockbox www.rockbox.org
remember to read alot before installing it
i give you a fast guide about the diffren´t modes you canm boot to :
1.normal only start it while dont push any button
2.recovery mode hold(activated) and push rec button when boot screen comes ( this can be used for reinstalling or uppgrade a mp4)
3.manufrakting mode start mp4 while push centerbutton hold(activated)
4. i think it was one more but i forgot that one :p
2answers
Rock box??
Go to rockbox home site dowload current bulid and read the manual , then re install rockbox and if you don't want to keep rockbox uninstall it , you will find how to do in manual
good luck
2answers
How do i clear
Some of that space is reserved for the firmware of the unit(the software that runs your mp3 player, controls all the menu's)
2answers
Crappy pictures
Describe wierd - this word means nothing. White flash images are over exposed- so reduce the ISO setting to a lowers number if the camera allows it. or Reduce power of the flash. The easiest way to do this is to put layers of tissue of the light reducing the intensity until you get it about right.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
