SOURCE: getting date on watch
udjust the date until the last date of month and surely the month will chagne thank you !
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second
hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown
all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands
will stop.
Step 2. Turn the crown to
move hands FORWARD (clockwise) until you see the date (for date only) or both
day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue
to move hands forward until the minute hand is approxim a t e ly 5 minutes
beyond the desired minute marker ;then ,gently turn b a ck to the same marke r.
For P. M .time , follow the same procedure ,but first a dvance the hands past 12 o’clock .
N O T E : The date will
advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been
established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The
refore ,on the fi rst day of any month
fo l l owing a month with fewer than 31 day s , the date must be advanced
manually (see Step 5).
Step 4. When the time
standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches
the 60th second, push the crown all the way to the “ I N ”position . All hands
will start instantly.
Step 5. Pull the crown to
the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will
continue to tell time. S l ow ly turn crown one way until the correct date a p
p e a rs .Then for day/date models, s l ow ly turn crown the other way until
the correct day appears .
N O T E : The day is printed
in two successive positions on the day indicator: i n English and in Spanish on
U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is
possible to make use of either position. The display will automatically re m a
i n in the language ch o s e n .
The
date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M
.a s this might affect the calendar mechanism and the accuracy of the date. (
Theme chanism will not be damaged if the crown is turned accidentally during
this
time
peri o d ,howeve r. )
Hope it helped U!
SOURCE: Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Testimonial: "I'm the one who submitted the question. Thank you, I will visit a watch repair shop. It's a shame the watch is only 2-3 months old! Thanks again "
SOURCE: GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
SOURCE: i'm tryng to set the date without changing the day
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
