Kyocera Taskalfa 180 machine... how to do main counter zero (0)??? plz help anyone
Change the fixing unit look your connecter are correct and go the servive mode 10871087 press 163 and clear this
Pls. send Free service manual with code for kyocera TASKalfa 180
[email protected]
Replace fuser
SOURCE: Morning,
1650 machine is a medium size machine for small offices and home users. The machine is equipped with a self diagnostic function so it displays an error code whenever its processor detects a problem during copy process.
Some codes can be reset by simply opening and closing the front door or by turning the machin on and off, but there are some others that can be reset only by a service representative. C 6000 code is one of them. There are several causes that lead to this problem, i;e:
1. Unstable power source
2. Low volatage
3. Broken thermisted wire
4. Poor contact in the thermister connector terminals.
5. Heater lamps are broken or not installed correctly.
Here is the process to reset c 6000.
Enter 1087-1087 (1087 twice) from the keypad.
U000 will be displayed.
Enter 163 by using the keypad keys.
Press "Start" (the green button) twice.
The code will be reset and machine will start automatically.
If this code is appeared again, you may need to check the fusing section of the machine and it shoud be done only by a service engineer.
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
SOURCE: Free service manual with code
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email [email protected]
Especially interisuet off hibernation.
1087+1087 u 163 start baton
I donot success agen sow
