If your Viore TV is unable to scan digital channels after a power outage, there are a few things you can try to fix the issue:
- Check the TV's antenna connection: Make sure that the antenna is securely connected to the TV and that there is no damage to the cable.
- Rescan for channels: Go to the TV's menu and select "Auto Tuning" or "Channel Scan" to rescan for channels. Make sure to select the option for digital channels only.
- Check for software updates: Make sure that your TV has the latest software updates. Go to the TV's menu and check for any available updates.
- Perform a factory reset: A factory reset will restore your TV to its original settings. This can sometimes fix issues with channel scanning. Consult the manufacturer's manual for instruction.
- Check your TV's location: Make sure that your TV is in a location where it can receive a good signal. Try moving the TV or the antenna to a different location.
If none of these steps work, it's possible that the TV's tuner may be malfunctioning and may need to be repaired or replaced. Contact the manufacturer's customer service or a professional technician for further assistance.
Regenerate response
