Question about Vizio GV47LF Television
Have a vizio E421va with sound and no picture. It appears to have some backlighting that works. What part might I need to replace?
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: No picture on vizio lcd
It's likely not a backlight, but a mainboard. If you are feeling frisky, take the back off and get the model number off the mainboard and check eBay.
Posted on Aug 22, 2009
Anonymous
  • 4 Answers
SOURCE: vizio vw42l, the vizio light turns from ornage to
Does LCD screen backlight come on? If so proceed....
USE:CAUTION WHEN DOING THIS....
Try this if repairing yourself...find power supply, small board with no cover over it...check voltages on output pins/plug/connectors (white plugs) three in a row...
1 Plug has 24Volt supply..1 has 12Volt supply and 1 has 5Volt supply when read to ground (screw that holds board in) if you have these voltages it's a safe bet it's the main control board...I just replaced mine and it fixed a problem like yours.
Posted on Sep 02, 2009
Anonymous
  • 13 Answers
SOURCE: Vizio TV 2006 vx32Lhdtv doesnt work.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
Testimonial: "If all things are equal than the solution is at hand. I thamk you!"
Chi Chu
  • 8457 Answers
SOURCE: I had my Vizio VO42L
Tv turn on now,have a flashes a picture only a few sec.than dies and have sound left only?Yes,than those 2 long boards to the left and to the right call the LCD inverter boards are dead.These 2 long LCD inverter boards,job are to help the LCD screen panel to have a backlight to produce a pictrue.Tries websites like Shopjimmy.com.Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Posted on Dec 08, 2010
kent mac
  • 362 Answers
SOURCE: where is the audio output on my vizio e421va
simply doesnt have an output at all some do some dont yours does not route the audio signals to an A\V receiver instead
Posted on Dec 20, 2010
I have a Vizio E421VA LCD HDTV and am getting a black screen. The power light comes on, but am still getting a black screen. Does anyone have the same problem and/or solution?
To determine if the backlight driver or the T-Con board is the problem, di this. With the TV on shine a flashlight on the screen. Look for a faint picture. If you can see one then the backlight control board is bad. If you see no movement or any picture at all, the T-Con board is bad. You can get the parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 17, 2017 | The Video Game Consoles & Games
Need a backlight for vizio model E550i-B2
Fixya does not sell replacement backlights.
Oct 08, 2016 | Vizio Televison & Video
TV has no picture, no sound just the VIZIO logo light is on the screen.
Did you check out the power supply for proper operation since both the audio and video are gone? If PS is good then the problem may very well be on main board.
May 03, 2016 | Vizio E421VA 42 in. LCD TV
Vizio tv has sound no picture
Hi Brenton,
You have sound and no picture. It appears to be a case of backlight failure which is common in LED TVs. The problem is technical and involves opening the tv, diagnosing and replacing or repairing the defective board. Please consult some good local TV tech. Good Luck.
Apr 28, 2015 | Vizio Razor E461-A1 46" LED TV 1920x1080,...
Getting no audio from speakers on a Vizio E421VA LCD HDTV, any ideas?
Do headphones work?
my guess is either the headphone socket or associated wiring/soldering is faulty or there is a faulty connector within (connector associated with the audio)
Jun 19, 2014 | Vizio E421VA 42" LCD HDTV
Some channels are snowy and some are clear and sound is not good on some channels as well.....i got the tv from a person who was having same issue so they gave it to me so i could get it fixed so was...
We literally have 1000s of LG TVs at work ranging from 32"-42" and beyond. Our joke is that LG stands for Little Good. We have to pay a few hundred dollars to replace the tuner board inside.
Jul 15, 2011 | Vizio E421VA 42 in. LCD TV
I just bought a Vizio E421VA last week. When trying to change the picture settings (brightness/contrast) using the Vizio remote, sometimes it just turns off all of a sudden. This also happened while I...
Hello, my name is Dan Busa with DISH Network. I happen to have seen this with other Vizio TV sets and would be very interested in taking a look into this. Even if you have resolved this please e-mail me at: daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Mar 21, 2011 | Vizio E421VA 42 in. LCD TV
Vizio model VW42LFHDTV10A 42'' LCD has no picture but has power and sound all buttons and remote work. Faded picture appears for about a second and goes blank. Everything else seems normal. I'm wondering...
This problems are those 2 long LCD inverter boards to it left and to it right.These 2 long LCD inverter boards help the LCD picture screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Nov 26, 2010 | Vizio VW42LF 42 in. LCD HDTV
VIZIO VW42L I have sound but no picture.
if there is entirely no backlight then yes, however if you just dont have a picture and just a blue screen then it is not the backlight it is the inverters, replace both is recommended.
Sep 19, 2009 | Vizio VW42LF 42 in. LCD HDTV
Vizio GV47LF Television Logo
245 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
