SOURCE: LCD kaput - anyone know of a panasonic recall?
The panasonic camcorder does not use the Sony CCD element. If the small viewfinder is showing the camera video, there's nothing wrong with the CCD imager. We have had numerous problems with the switch that controls the activation of the large LCD and the backlight inverter that powers it. When you open the LCD the small viewfinder should power down to conserve battery power. The large LCD should then illuminate, if not, shine a flashlight at the surface of the LCD and notice if the video is present, if so, the backlight or LCD harness is defective. Joe Weibel Custom Electronics (customelectronics.org)
SOURCE: transfer my video from panasonic sdr - h40
try to use USB to plug your device to your computer. make sure that you have an installed driver for your camcorder to recognize your device on your pc. all brand new camcorder came with an installation software cd. now your ready to transfer your video to your computer. use any movie maker application like ulead movie maker, nero movie maker or windows movie maker edit it and save it. burn it to your vcd or dvd burner to play on your dvd player. if you dont have a driver i will find one for you. hope that helps!
CHARCOIS
SOURCE: Panasonic SDR-H40P Hard Disk Video Camera loses focus
Keep it still roughly 5-6 seconds in the same spot and it will re-focus
i had that once
SOURCE: getting fisheye lens or wide angle lens on Panasonic SDR-H40P/PC
what is the size of the ring adapter
you will need to connect your camcorder to your computer
click start click on my computer to open from there you should see your camcorder then right click to select open you should see the data/files in there select what you want to delete right click select delete or you can right click select format this will delete all data on hard disk
hope this helps you
