Question about NEC VT460 Multimedia Projector
Nec vt540 vt540k
I have a nec vt540k and it stop projecting images. When i turn it the power led turned in solid green, the fan start working withouth problem but in few seconds the status led turned it in yellow blinking 1 second cicle three times after that the power led turn it in yellow and the staus led in blinking red 6 second on and 6 second of... I readed the manual an it only say what mean when the power les is solid yellow and status led blinking by 1, 4, 8 and 12 second dont mention what means power led in solid yellow and status led in blinking red 6 second space. I need help in this...
  • William Ayala Oct 07, 2013
    Thanks neo32... I did exactly how you suggest to me and no light come out the lent... So i think you have right... But how i can fix that and where i can get that ballast?
    New Friend:
    Problem Solver:
  • 5 Answers
Probably needs filters cleaning or a new lamp replacement.
Posted on Nov 15, 2013
2 Suggested Answers
Anonymous
SOURCE:
Neo32
  • 74 Answers
SOURCE: HELP! I changed the bulb already. My NEC VT 470
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Posted on Apr 16, 2010
Nec np-m260
be more specific. no power? no image? no light? if there is no led lit, power supply problem. if the led is on but the fan doesn't turn on when the power is pressed, either the dc fan is seized or a board level fuse is blown. if the fan won't turn on, usually the light won't either. if the fan is on but not the light, the lamp may be blown. if all is on and no picture, check your inputs.
Mar 02, 2014 | NEC Office Equipment & Supplies
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
InFocus LP130 - lamp doesn't turn on, front fan doesn't spin, LED doesn't turn on.
HOLD THE POWER SWITCH ON BOTTON OF THE UNIT
PLUG THE POWER CORD TO THE ELECTRICITY SOURCE
RELEASE THE POWER BOTTON AFTER 10 SECONDS
AND THEN TURN ON THE UNIT...
OR YOU MAY GO TO THE SITE (freepatentsonline.com) search the brand of the device....GOODLUCK.
Dec 06, 2011 | InFocus LP130 Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Pink cast in images from NEC VT540/440 projector
Sounds like one of those problems only cureable with expert knowledge of for example Chroma feed , Lcd function , lamp luminence, not to be a killjoy but it sounds like this is one for the engineers an estimate should be free and even if you dont have it fixed you'll know whats wrong if you want to do it yourself providing you have adequate training of course .... Regards vortash
May 08, 2009 | NEC Office Equipment & Supplies
NEC MultiSync VT540 not turning on - Temperature error
Hi
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
Sorry for my english
Feb 18, 2009 | NEC MultiSync VT540 Multimedia Projector
Tv wont trurn on
Re-check the lamp door alignment. If the door is not installed properly, the interlock switch will open causing a no start condition. Also observe the red LED on the front panel. When you turn on the TV, a gree LED will blink on and off until the image appears. If the image fails to appear the green LED will give way to a red LED that will flash a specific number of times in between pauses. 3 blinks means the door is not installed correctly. 4 blinks means that a fan has stopped working, etc.
michtech
Feb 17, 2009 | Sony KDS-50A2000 50" HDTV
When trying to power up the status light flashes yellow 3 times and goes off it does it again then it flashes red 3times then it shuts down the bulb never comes om just the fan. i have a nec vt540...
I want you to see this document to troubleshoot your projector.
www.douglascollege.ca/__shared/assets/NECVT440K-540KMANUAL32259.pdf
Goto page no: 35 . It has information about status light messages and i hope it will help you.
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | NEC Televison & Video
VT540K Won't power on
needs new lamp http://www.necvisualsystems.com/Documents/UserManuals/MAN_VT440-540.pdf
Feb 13, 2008 | NEC MultiSync VT540 Multimedia Projector
NEC VT460 Multimedia Projector Logo
252 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
