truckpartsinventory.com > Hoods > Freightliner Freightliner Century Class C120 BBC Fiberglass Hood Shell. Fits Models from 1997-2002 with Old.. ... Shell (Economy). Fits 2002 - 2004 Models with New.
https://www.heavytruckparts.net/search.php?...FREIGHTLINER...CENT... Active Truck Parts Hood FREIGHTLINER CENTURY CLASS 120. More Info ... HoodFREIGHTLINER CST120 CENTURY, 2002, 1FUJBBCG92LJ79765, Hood
Abs sensor will need replacing, cleaning them won't help, you need a code reader to see which one needs replacing then you need the code reader to delete the fault code
following the line connected from the front mounted condenser to the compressor pump at front of engine , it's mounted in that line ,(small) use extreeme caution as theres a lot of pressure there on that line , fyi if your expansion valve is plugged your compressor is bad as well!!
it is a slim chanch of it being ur data link sounds to me like the x-y shifter has gone out should be able to hook up pro link and get the code have had to replace many of these shifters that has done the same thing hope this helps J & R Truck & equip repair
