Question about NEC Electra Elite 32D-1 Corded Phone
Caller id now shows number instead of name (new provider)
We changed phone companies. Now caller id shows phone number instead of name. New provider says we are programmed for name and number--same as previous provider. What do we need to do to have name displayed? We don't have a NEC service tech. Is this something we can do ourselves?
  • 149 Answers
This is something you could be walked through with tech support. They would need to know what type of system and what cards are in it, in order to program it. ldtsnj.com
Posted on Jun 16, 2009
6ya staff
SOURCE:
Panasonic dect 6.0 plus name and number of incoming calls aren't showing on phones. How can this be fixed?
Do name/number display on any other phones on that line?
If that is your only phone, try borrowing another with working call display from a friend or neighbor. If another phone doesn't display caller info, call your phone company - most charge extra to provide caller number ( and in some cases, another extra to add the name). Even if the features are included in your rate, it's possible they weren't turned on correctly.
Your Panasonic may also have a setting to show name or number - depending on the display size, you may have to pick one or the other.
Finally, some phones do not support exactly the same caller ID info that the phone company sends - I have seen some which displayed number instead of names and no name, just because the two pieces of equipment did not agree on the standard. Try your Panasonic on someone else's line with working Caller ID.
Oct 12, 2017 | Panasonic Lands Phones
I am using 'Ativa D5765 cordless phone
You must have caller ID provided by your local phone company for Call ID to work. This is an additional charge on your phone bill.
Feb 21, 2012 | Lands Phones
When there is an incoming Call, the display shows,
Feb 21, 2012 | Office Depot Ativa D5765 58 GHz 1Line...
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
Caller id is not working in my cordless phone. Instead of number of a caller, "Incoming Call" is showing. Please help me
Caller ID on landline phones relies on signals from the telephone service provider. Some companies charge extra if you wish to enable the service, others include it automatically, so you need to check with them first.
Even if you have caller ID enabled, callers can choose to withhold their number. Large companies which make lots of outgoing calls (especially cold callers) often have their service set to automatically withhold their number. In many countries, all other callers can choose to do so by prefixing all dialled numbers with a short code, e.g. in the UK it's 141. Mobile phone callers can usually alter a setting on their handset so that caller ID is withheld when making outgoing calls.
Sep 29, 2011 | Lands Phones
Caller ID problem with KX-FHD332
Your fax machine does not actually have CALLER ID, it reads what the sending fax machine has programmed into it. If it was never entered in, you won't see it.
Jan 13, 2010 | Panasonic KX-FHD332 Plain Paper Thermal...
My caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
Dec 04, 2009 | Panasonic KX-T7731 Corded Phone
Caller ID posts incorrect name with number What
Some telephones, just like your cell phone, will show the caller-id name you have programmed into the phone-book memory. If this is the case, then the solution is an easy one, just change name yourself.
If this happens on every caller-id phone or box in your house, then you should call your phone company as there CNAME database might be corrupt.
However if this only happens on the GE phone you mentioned and there is no phonebook memory in it, then I suggest exchanging the phone.
Sep 03, 2009 | GE Lands Phones
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Caller ID Display
There is no setting in the phone that will show you the Caller ID number without the name. It sounds like your telephone company is not sending the name.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Mar 31, 2008 | Panasonic KX-T7633 Corded Phone
NEC Electra Elite 32D-1 Corded Phone Logo
234 people viewed this question
Top NEC Lands Phones Experts
Ekse
ray gallant
Andrew Taylor
Andrew Taylor
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
