SOURCE: DVD stops playing in middle
What might be happening is a misread of the disk or a buffer error, these happen often, and can be fixed sometimes by cleaning the lens, cleaning and relubricating the guide rails and making sure the rubber bumper gromets are not worn down. Now these are all of the mechanical things you can do. The problem could also be a bad memory sector in the play back buffer, or a store and hold voltage could be off a bit (indication of a bad capacitor). I hope this helps.
SOURCE: Player suddenly freezes
Try running a dvd cleaner through it first, before trying anything else (the type that looks like a DVD with a brush underneath).
The regular DVD might have been a fluke (scratches, rental?, burned dvd?)
Was there anything special about the new Blu-Ray Disc - what was the tile? On certain titles, you may need the firmware upgrade found at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300
SOURCE: player says "no disc"
Hi Thomas!
You may try installing the latest Firmware update from the link given below:
http://www.esupport.sony.com/US/perl/swu-download.pl?upd_id=4704&mdl=BDPS300
Please read all information thoroughly before downloading and installing the file.
If the issue persists then try performing the following troubleshooting steps:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1001161
If the issue persists even after performing all the above steps then service will be required.
SOURCE: image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
SOURCE: dvd player tray keeps opening and closing.
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
