One of the red lights is staying on. The fast freeze is still working some defrosting but not total. Think the lid was up for 12 hours could this be the cause?
THE RED LIGHT IS ON ALL THE TIME ON MY CHEST FREEZER. THE GREEN LIGHT IS DIM. SHOULD I PRESSIN THE AMBER LIGHT . HOW CAN I GET MY FREEZER TO WORK. I HAVE DEFROSTED IT 2 HOURS AGO. I SWITCHED IT ON BUT IT DOES NOT SEEM TO BE COOLING THE RED LIGHT IS ON ALL THE TIME ON MY CHEST FREEZER. THE GREEN LIGHT IS DIM. SHOULD I PRESSIN THE AMBER LIGHT . HOW CAN I GET MY FREEZER TO WORK. I HAVE DEFROSTED IT 2 HOURS AGO. I SWITCHED IT ON BUT IT DOES NOT SEEM TO BE COOLING
AnonymousMar 28, 2014
freezer alarm going off switched to super freeze but everything is slowly defrostingfreezer alarm going off switched to super freeze but everything is slowly defrosting
You can't post conmments that contain an email address.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
Since the motor is running, the compressor it is connected to must also be running. The compressor is the thing that provides the cooling under normal circumstances. The only thing I can think of as to why you are not getting cooling is that the refrigerant charge has leaked out of the system. I don't know anything about the red lights you mention.
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
red light on freezer
