Hi everyone. I'm having an issue with my samsung NP535U3C. The issue is on the brightness controller (using multimedia keys). Everytime I put my notebook for charging, I can control the brightness' screen. But when I use it on battery power, I can't control the brightness screen and besides this, the battery power drops to 50% Can anyone help me? Thank you
SOURCE: Samsung NC10 Fn key inactive
Go to Start, All Programs, Samsung, then Easy Display Manager Option. Make sure that the "Advanced Volume" is enabled. Somehow that also enables the other functions. I couldn't use my function key for anything but after I enabled advanced volume, the function key was working for brightness, sound, F4, etc.
You also have to make sure that the Magic Keyboard is on.
Hope this helps!
SOURCE: Samsung NC10 Screen goes white when plugged into Charge
I too had this problem with my NC10, and i found that on the back, the little slider holding on the battery casing was not in the locked position. As soon as I locked the slider, the problem was solved and has not occurred again.Might not be the case for all these posts above, but worth checking your before having to get involved with customer services etc.
SOURCE: i have a samsung nc10 notebook, when charging the
Hi
The problem you are experiencing is from either the screen of your laptop,the screen board which holds the screen in place or the screen bulb which lights up your screen.
You should get an expert to diagnose which one of the three is faulty, but at least one of the three things i have listed is faulty.
Thank you for visiting fixya
Try a system restore and take computer back in time before this became an issue.
SOURCE: samsung r519 charging port problem
Try someone elses charger in your pc, if same fault, its your pc
