HI, Do the following for unlock the parental control. For this you should need the remote for the DVD payer. 1. Press the set-up button on the remote (set-up display will come on the TV screen ) 2. Using Right arrow button or Left arrow button select DVD Setup menu 3. Using Down arrow select Parental control and press Enter button 4. now you can change the parental rating using up down arrows If it ask for password the read the following carefully and do the same and enjoy your videos. PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD
Player to only those DVD discs that do not exceed the rating you specify. When
the Parental Control is set, DVD discs that support this feature will play only
after the password has been entered. However, typically only discs produced by
major entertainment companies support Parental Control. Discs not supporting
this feature will be "immune" to Lock-Out.
When you attempt to change the Parental Control setting, you are
prompted for a password. This of course makes sense, as this option would be
useless if your kids could enter the Setup Menu and disable it! If there is no user
password set, you'll be prompted to enter a new password. Choose a 4-Digit
numeric password and write it down in Case
you forget it. Key in the password and press ENTER. After the password is set,
press ENTER on the CHILD option. You can choose from 8 levels of Parental
Control, corresponding to the standard rating system in the USA. The available
levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the
default factory password. The procedures to change an existing password or
enter a new password are the same - you
must enter the OLD PASSWORD, then key
in your new password twice to confirm. If you are entering a new password, or replacing a password you
have forgotten, use the factory default
password of 3351 as the OLD PASSWORD. If you are changing a previously entered
password, you may enter that value as the
old password.
A. Remember to keep
in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password
written in a safe location as a reminder if needed Ajin
There are two methods to reset the Parental Control on a PlayStation 2, the Quick Method and the Easy Method.
The Quick Method to Reset Parental Control
Power on the PS2
Press the Reset button
Inset an R-rated and wait until the board comes up telling you that Parental Control is on
Hit the Select button
At the enter password prompt, hit the Select button
At the Delete password prompt, enter in your password
Hit the X button
If you do not know the Parental Control password on your Ps2, try the known defaults of 1111 and 7444.
The Easy Method to Reset Parental Control
Parental Control Blocks playback of rated DVDs based on their content. Not all discs are rated.
1. In DVD Stop mode, press SETUP. 2. Select Others > Parental. 3. Select the desired Parental Control rating from "1 Kids" to "8 Adult", then press ENTER. 4. Enter your password using the 0-9 keys, then press ENTER. ā¢ The factory default password is 3308. If you forget your password, this will always work.
Password Changes the Parental Control password. 1. In DVD Stop mode, press SETUP. 2. Select Others > Password. 3. Enter your old password using the 0-9 keys. 4. Enter your new password. 5. Re-enter your new password and press ENTER.
hello
Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control (the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
I have forgotten the password for my parental control/content adviser window. Can you help me either remove it or change it without knowing the existing password. Thank you!!
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
