SOURCE: i just bought a marshall MG 100FX amplifier. What
IF YOU ARE USING THE LEFT INPUT OF THE AMP PLUG IT IN ON THE LEFT INPUT OF THE 212. RETURN AND SEND.
SOURCE: my mg 100fx has a scratchy pot in the master
What did you spray it with? I hope NOT Deoxit or Blue shower as those wreck the pots by removing the lube.
Use CRC226 available in the electrical dept at Home Depot. Use the plastic tube by bending it so it can spray upward into the slot where the leads that solder into the board go into the metal can.
Spray a little in and work the pot... then try a little more and see if it improves the situation. If it does, treat all the pots the same. ALSO look for broken solder where the pot wires solder to the circuit board..
SOURCE: low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at [email protected].
