Hey i just bought an 160 GB Seagate SATA HDD but after i connect it to my motherboard it's unable to detect it I don't even get it in the BIOS I booted from my WIN XP CD and it says no HDD atached Pl help :(
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sata disk is not detect.and quit setup f3
How install win xp
Search XP Dark Ed. form www.katz.cd
Go www.katz.cd and find XP Dark Ed. and enjoy
Can you help me out from this problem.
I am using ASUS P5RD1 VM series motherboard and Samsung HD080HJ SATA HDD 80 GB.
My problem is that when i do switch on my PC it detects my DVD-ROM, CD-ROM and Hard disk but it does not shows it in Bios setup and during installation of Windows XP SP II it shows
"Setup did not find any hard disk drives installed in your computer."
In starting(when i Switch ON my PC) it shows DVD-ROM as Primary Master and CD-ROM as Primary Slave & SATA HDD as
3rd Master..IDE Hard Disk and it shows DVD-ROM and CD-ROM same as Primary Master and Primary Slave in the Bios Setup but did not shows any Hard Disk Drives. Moreover, SATA HDD is working properly on another PC and i am using only one SATA Hard disk drive in my PC.
I had checked it with both options in Bios Setup as "SATA Controller enabled/disabled".
Kindly suggest me with some solution to come out from this problem.
SOURCE: Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
SOURCE: raid problem
Windows XP does not support SATA you need to load the SATA drivers from the motherboard manuf. You should have a cd for RAID/SATA drivers. When you boot off the XP CD it give you an option to load third party drivers watch at the bottom of the screen. When you see this message you can insert the CD that contains the drivers it is looking for the you should be able to load Windows XP.
I hope this help. Please rate.
not detecting the sata hdd
Hey i was able to install Windows on the new SATA disk
so now I have windows on both IDE and SATA disks
If i boot my pc with IDE and SATA both connected it gives me the option of loading ne one of the OS
but if i remove the IDE disk and try to boot only from SATA it doesn't load the OS and just a blank screen witht cursor at top left coner is displayed.
M i missing something here ?? do i need to do more settings ??
yes
I have installed the drive from the makedisk.exe program and during the windowsXP install after loading the third party drive with the F6 option,
the installation still does not detect the drive which is configured as RAID1 SATA. using the ULi driver.
can someone help me out from this problem.
My problem is that when i do switch on my PC it detects my DVD-ROM, CD-ROM and Hard disk but it does not shows it in Bios setup and during installation of Windows XP SP II it shows "Setup did not find any hard disk drives installed in your computer."
In starting it shows DVD-ROM as Primary Master and CD-ROM as Primary Slave & SATA HDD as 3rd Master..IDE Hard Disk and it shows DVD-ROM and CD-ROM same as Primary Master and Primary Slave in the Bios Setup but did not shows any Hard Disk Drives. Moreover, SATA HDD is working properly on another PC and i've only SATA drive not any other drive.
please suggest me some solution for this problem.
regards
BAwa
hello , i am purchasing asus p5rd1-vm mother board. installing winxp sp2
no hdd detected . please any solution
80 Gb seagate sata did'nt detecting
1. how can i view sata option in this motherboard
2.how can i instal os without raid contol use
sata drivers for hdd on p5rd1 motherboards
i have sata HDD with ASUS P5RD1-VM Mother board & i can't install windows xp as it shows that it can't find any HDD or the hard disk is not properly connected.....what should i do???????
bt when a general HDD is connected for installing windows xp, it works as normal.....even when i connected my hdd with an another mother board of asus model no 6100, then also it works properly.....actually in all the other cases my hdd is selected by the mother board whereas it fails to detect it in my own pc....
i'm using mother board ASUS pdr1 and whin i install win xp it doesn't detect the hard disk drive ....please help me and say what i have to do to resolve this problem
i have not my motherboard cd and i can't disable raid in my pc my motherboard is p5rd1-vm
my samsung 160 sata hard disk is not detected by the pc
my pc not found sata hrad disk when xp instalation
I have SATA HDD 80GB and motherbord P5RD1-V, I can't instal Windows XP because I haven't driver for sata
