Question about Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White
My Maytag 2454GR side-by-side refrigerator is not cooling. The freezer went out first and then the fridge and was like for a couple of days. Then last night it started making ice again. But this morning I noticed a puddle of water. I opened the freezer and the ice was starting to melt again just like it did the first time. What could be causing this problem?
  • Maytag Master
  • 4,656 Answers
My Maytag 2454GR side-by-side refrigerator is not - 6a2cba52-efc5-4691-80a0-df6735f3f203.jpg
A defective 68233-2 Defrost Timer will cause the same symptons. Sea Breeze
The Defrost Timer is part location 13 in the photo HERE
another source for the timer can be found HERE
Posted on Oct 10, 2013
6ya staff
SOURCE:
John McPherson
  • 1212 Answers
SOURCE: Fridge and freezer not cooling
When the refrigerator turns on, do you hear anything in the refrigerant lines? Does the compressor turn on? or does it just hum?
If the compressor is running, it lost refrigerant charge. They were not made to be serviced and lack service valves.
If there is just a loud hum, the compressor may be siezed, the start/run capacitor may have failed. or the magnetic starter failed.
A service call is a fair portion of a replacement not counting the parts.
Posted on Apr 30, 2012
SOURCE: Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Posted on Nov 22, 2008
Anonymous
SOURCE: Water on floor from freezer side of Maytag side by side unit.
Yes I just had that happen to me. An appliance guy came over for my stove and I asked him if he could tell me why I wake up everyday to a puddle. He told me to take the baskets out unscrew the three screws and pull the panel off, then pour some hot water in it and use a turkey baster to blast the drain hole with. It worked. Sears repair man couldn't even figure that out when it was under warranty. Took me 15 minutes. Good Luck
Connie Marie
Posted on Aug 14, 2009
Sal De
  • 2699 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Maytag MZD2766GES refrigerator quit cooling, both sides.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Remove the cardboard backing from the back bottom to access the compressor area.
Posted on Dec 20, 2009
Apr 30, 2012 | Maytag MSD2732GR Side by Side Refrigerator
Fridge is not staying cool after defrost--only stays cool for a couple of days then stops cooling until we defrost again
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Lights on, fan on freezer and refrigerator not- maytag mzd2665hew
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 11, 2010 | Maytag MSD2655HE Side by Side Refrigerator
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frozen coils in freezer side of fridge/ freezer s/s
had the same problem with mine. found out it was the defroster timer circut board. mine was located in the reffidgerator side underneath the panel where the slide controls are. went to parts store and bought a new one for $35.00. it unplugs and plugs in easy. found out it's a commen problem and happens every couple years or so.
May 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Logo
222 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
