SOURCE: GSS25VGMD refrigerator not cooling evenly
i would observe the back wall for frost or ice accumulation if there is i would check the defrost circuit. the heater would be first, if it is good check the sensor is more than suspect. the defrost sensor is the one on top of the evaporator. If no ice is present open the door and feel the cabinet where the gasket touches on the frame. if it is extremly warm that would indicate that your condenser fan on the bottom at the back of the unit is out, this would also cause the symtoms you are having
SOURCE: GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
SOURCE: freezer will not get cold
Hi..
You need to check this following:
Good luck !!!
Regards
PCmania
SOURCE: GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
SOURCE: after power outage, fridge does not work but freezer does
Sounds like a thermostat got damaged when the power surged when utilities were restored. Thermostats are usually behind the temperature controller. Hope I've helped. BB
