When I turn on my Toshiba Portege laptap I get a message asking me to "Select Boot Device:
C : CD Rom
N : Network (LAN)
U: USB Floppy Drive
1 : Primary Hard Drive (Built In)
2 : Secondary Hard Drive (Select Bay)
P : PC Card Hard Drive
D : Default SYSTEM SETUP Device
Pres C, N, U, 1, 2, P, or D"
No matter which option I choose it says;
" Intel(R) Boot Agent Version 4.0.18
Copyright (C) 1997-2001, Intel Corporation
PXE-E61: Media test failure, check cable
PXE-MOF: Exiting Intel PXE ROM.
Insert system disk in drive.
Press any key when ready...."
Can you help with the problem, I don't have a clue what's wrong and I'm using my other laptop to deal with this.
PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel PXE ROM. Insert system disk in drive. Press any key when ready...."
This is a easy fix all you need is a windows xp installation disk.what you do is put the disk in and boot off of the cd option.if you need help with the xp cd installation i can write up a guide for you.also is the first harddrive new or came with the comp.if it is a new harddrive it might not have a operating system on it.email me if you have anymore qeustions or you want the guide.i can even make a video for you but it probably won't be good quality.
Sounds to me like you have been messing with your bios settings. if your laptop still has a os installed onto it and you have not foolishly erased your hard drive then this what it is looking for at the bootup stage and it has to be directed to it manually within your bios. go into your bios and look for something like hard drive priority and make sure that it is directed to your PRIMARY DRIVE where your operating system [OS] should be. hopefully your problem is solved, well i know it will be. good luck, and DON'T MESS WITH YOUR BIOS UNLESS YOU KNOW YOUR WAY!!
It means that the BIOS cannot find a disk to boot.
Make sure you selected the hard drive in the boot settings of your BIOS
Remove all external DVD drives or floppy drives or ethernet cables
If you get an error message, you should start troubleshooting your hard drive.
This is in case you cannot boot into windows but you can get into bios:
Open your disk drive. Insert windows operating system disk into your disk drive. Restart your computer.
If you can get to the stage where you can see see bios entry key then
keep pressing whatever key it is that you press to get into bios at
start up.
Select the option that let's you choose the drive to boot from, mine is
in advanced bios options. then go to either something like bios features
or change boot drive.select whatever drive represents your CD-ROM drive
and select it to be the first boot drive.
then save exit bios, I do this by pressing escape then Y to save and boot from the rom drive.
This will let you restart your installation of windows and
re-format the drive...
If you can boot into windows:
Then either re-format the drive and delete the partition when you do or...
Run a recovery of the system by installing your disk and letting it get
to the stage wher it asks what action/task you want to perform and
press r when prompted then follow the prompts to repair the files. This
might not work though,
you could even try running a disk check as maybe a lucky chance of repair if you can get into windows.
If your PC keeps trying to boot from the CD drive after repair then
re-enter bios at start up and change your hard drive back to first boot
device to boot into windows.
It's better if you re-format though as repairing windows can be a little tricky.
I have been installing XP on Portege M200 laptops.
I use a usb floppy to install the latest bios update from Toshiba's support site.
After the update the laptop will boot from a USB Cd/DVD drive.
be patient the first part of the up date goes extreamly slowly but it seems to keep working and the install will work.
NOTE: Ususally when computers DO NOT find any startup information on the SELECTED DRIVE (like when you click a key) it goes to the default drive. WHICH IS YOUR HARD DRIVE. Meaning it is probably your Harddrive is broken, or your connection from hard drive to motherboard is broken
Burn a Live CD bootdisk of some linux distribution liek Slax, google it. Burn it to a bootable CD and put it into your drive, then select to boot from it. If it boots only using your CD ROM drive, if that works then its probably not your BIOS/rest of computer, which is good.
And while in the live cd, you can see your harddrive and see files, that means its not broken its just your connection to it....either way im guessing youll have to send it in.
I assume the pc does not boot to windows without this file. You can reinstall windows. However, this will likely remove your data in the process.
If you can get into the BIOS, see if it can boot from the network or a USB drive. If so you can download something based on Linux that you can so boot and that is able to read/write to NTFS partitions.
The easiest way to replace this file for someone with little or no experience in these matters is to remove the hard drive from the tablet & hook it up to an IDE/SATA to USB adapter. Then plug it into a desktop.USB Port and it will be seen by the host PC as an add on hard drive.
doesn't ******* work
