Groove Tubes Power Back 5,250-Watt Portable Generator #GT5250-WK Logo
K
Kenny Singh Posted on Oct 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ive a GT5250- WK PowerBack generator and it's leaking oil from I don't know where. Can you help?
Alan Gowar
Level 3:
Master:
  • Master 452 Answers
  • Posted on Oct 13, 2013
Alan Gowar
Master
Level 3:
Master:
Answers
452
Questions
0
Helped
93838
Points
1017
Usually its the seal were the geny joins the engine u will need to separate generator from engine check the seal and replace with new one,
1 Related Answer
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Aug 29, 2011
SOURCE: Power Back generator model GT5250
You definitely have a carburetor problem.
If your carburetor has sat for a few months with fuel in it, the fuel may have gone bad. Fuel turns to turpentine after a while and leaves light yellow deposits behind. These deposits will keep your carb. from working properly.You need to dip the carb. in carburetor dip for a few hours to get rid of the deposits. You can also take the carb. to your local parts store where they may do it for free.
You may also have to replace the gasket and needle valve too if it has been sitting. So basically, you need to do a carburetor rebuild.
If the float sounds like it has liquid in it, you will need to replace it too.
Good Luck!
Jim
3helpful
3answers
What is on and what is off?
1 is on, 0 is off (binary)
Powerback gt5250 generator starts but wont keep running
Are you sure the float level is OK? Is the fuel old? Is the air filter dirty?
1helpful
Oil type
If you are asking about the engine oil, generators like the 10W 30 weight oil, which is good for winter and summer use. . The brand doesn't matter to any gret extent. Just don't buy the el cheapo brand in the dollar store.
I've noticed oil leaking from the unit but don't know where its coming from.
check at joint between engine and gen, its usually the engine oil seal need replacing u will need to split engine from gen, and replace the oil seal
Power back generator model gt5250 gas tank leaking
There are many products available at auto parts stores that are made to fix active leaks in fuel tanks. Go to one and ask!
My powerback 5250 portable generator will not start. Have check fuel line and replaced filter. Removed carburator bowl, cleaned it out and noted that when I gently pulled down on the float valve that no...
remove the tap from the tank
they have a habit of corroding internally and blocking the fuel flow
there is also a very fine filter in the end of the tap in the tank
do not use e-mix fuels as that fuel corrodes aluminium and rusts steel
Low oil. Do I fill through opening where dip stick is located?
yes that is where you fill the oil from be sure notto overfill
2answers
Powerback 5250 no electricity at outlet, alternator hot, pressed reset no change
If alternator is hot without load the generator may have short circuit in windings or on terminals.
2helpful
2answers
My 5250 watt Power Back generator will not start, and their is no spark at the spark plug.
Have you check the engine oil level?If it is down on oil you won't get spark because of the oil level switch shutting the ignition down to protect it's self.
2answers
Motor runs wide open but no power from generator
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
Top Groove Tubes Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you a Groove Tubes Electrical Supply Expert? Answer questions, earn points and help others
