Question about Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System
WIRE FOR 2 SPEAKERS MISSING --WHERE CAN I GET ..
2014 dodge advenger radio wiring harness diagram
2014 Dodge Avenger Car Audio Wiring Diagram
Car Radio Battery Constant 12V+ Wire: Red/Brown
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
C
Car Radio Antenna Trigger Wire: Gray/Orange
Car Audio Front Tweeter Size: 2-1/2? Tweeters
Car Audio Front Tweeter Depth: 5?
Car Audio Front Speakers Size: 6? x 9? Speakers
Car Audio Front Speakers Depth: 4?
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Gray
Car Audio Rear Speakers Size: 6? x 9? Speakers
Car Audio Rear Speakers Depth: 4?
May 18, 2016 | Dodge Cars & Trucks
The radio in my 2003 Suzuki Vitara has power but does not comes on factory or aftermarket
Sounds like either the speakers are shot, missing or not hooked up.
Mar 24, 2015 | 2003 Suzuki Vitara
I have purchased a soniq QSP421T. It has no sound and I noticed the cords are missing for the speakers. What do I buy to make it work?
The manual can be found here: ftp://ftp.quatius.com.au/Manuals/qsp421t.pdf
The speaker connections are simply spring loaded contacts so any 2-core bare ended cable can be used e.g. bell wire. Push the lever on the spring terminal down to open the terminal, then insert the bare (exposed) wire portion of the cable into the terminal and release the lever to hold the wire in place.
Jan 21, 2015 | Televison & Video
On the connection for my Boston Vr2 Floor Speakers there are 4 connections which are connected vertically with a brass plate which is approx 1/2 " wide. I have lost one and the speaker does not seem
You can use a piece of speaker wire to replace the missing bar. those speakers are designed to be used with the bars in place for normal use. they can be removed if you are bi-amp/bi-wireing them.
Jan 14, 2013 | Boston Acoustics Audio Players & Recorders
Trouble re-installing original radio to my 2005 Dodge Stratus, how many connections are there?
Here is a list.
2005 Dodge Stratus with Infinity Radio Wire Harness Colors
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Illumination Dimmer Wire: Orange/Brown
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: Dark Green/Red
Car Radio Amplifier Location: Amplifier is Mounted Under the Front Passenger Seat
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Dark Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Violet
Right Front Speaker Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Dark Blue/White
Right Rear Speaker Wire (-): Dark Blue/Orange
Sep 18, 2012 | 2005 Dodge Stratus
What is the color codes to a pioneer dxt-2266ub? putting it into a 1997 firebird.
PIONEER STEREO DXT-2266UB
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Owners Manual = http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DXT-2266UB_OwnersManual0607.pdf
1997 PONTIAC FIREBIRD WIRE COLORS
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (-): Light Blue
Hope this info helps
please let me know if you need any further info
May 20, 2011 | Pioneer Car Audio & Video
I have a 1997 s10 4x4, and my memory wire is missing, i need to know what fuse, or wire i can run the wire to so i wont have to keep reseting my radio?
1997 Chevrolet S10 Pickup Truck Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 14, 2010 | 1997 Chevrolet S-10 Pickup
Installing a after market stereo and need a color diagram of existing wires ithad an am/fm with cassett. Radio is missing and all I have is a bunch of wires to look at! I have more wires than places to put...
1995 Ford Econoline Van Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6′ x 8′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jun 12, 2009 | 1995 Ford Econoline
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System Logo
24 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
