Ricoh Aficio 1027 All-In-One Laser Printer Logo
Posted on Apr 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
  • rildo yulo May 11, 2010
    tenho uma imoressora SPC 811 que esta apresentando cód SC 548, executei o reset, verifiquei o termostato, termistor a lampada, e não resolveu. O que faço agora?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2496
Points
6
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Anonymous
Level 2:
  • Expert 95 Answers
  • Posted on Apr 23, 2009
Anonymous
Expert
Level 2:
Answers
95
Questions
0
Helped
75793
Points
192
Fuser code. You have to enter service mode to reset it. 5-810 and select execute to reset.
Anonymous
Level 1:
New Friend:
  • Posted on Oct 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2496
Points
Service code SC 670 on a Ricoh Aficio 2090, what is it and how to correct?
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
3answers
SPC 430 DN. How do I correct error code SC 315?
Consult the owner's manual troubleshooting section. Search the internet for:
Make + Model + the words "SC 315"
13helpful
3answers
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
9helpful
HOW TO ACESS SERVICE MODE RICOH SPC 811DN
Press the UP and DOWN arrow keys together for 5 seconds or more, and then press the OK key.
3helpful
Code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
1helpful
I have a Savin 9955DP/9965DP copier with a funtional service code SC548-00 is there anything i can do to fix the problem?
The SC 548 error usually occcurs in the fuser section when it ahas been reset incorrectly the drive and gears are not locking properly or the sensor has not registered the fuser correctly I would look in these areas check the seating of the fuser you can reset this in the modes with 5-810 sc reset then turn off.
I have a ricoh 1027 but it does work codes sc 548
You have a problem with your fuser - either an overheat, or lack of heat. Can only be reset by technician in a service mode, once it is fixed
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
