Sony MKS8010B System Control Unit Logo
Andreas Kozakopoulos Posted on Oct 13, 2013
I am looking for the lay out of the 15pin tally output
Gene Simmons
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 05, 2018
Gene Simmons
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
97
Points
MKS-8010A/B : (D-Sub 15-pin, Female)
Editor Panel Port
Pin No. Signal Name Function
1 GND Ground
2 RX- Received data (-)
3 TX+ Transmitted data (+)
4 GND Ground
5 - No Connection
6 +12V +12V
7 +12V +12V
8 +12V +12V
9 - No Connection
10 RX+ Received data (+)
11 TX- Transmitted data (-)
12 GND Ground
13 GND Ground
14 GND Ground
15 GND Ground
My computer due to power failureand when i restarted it again my tally 7.2 showed this message ....
It is your computer, showing something went wrong (serious wrong) with the Tally program. It is even telling where to look. But you should look it up on the Megaleecher website.
Recover Corrupted Tally Accounting Data
How to export tally 9 to excel sheet
Great question and there are two way export date. Please follow step by step instruction.
  1. In the Balance sheet screen click E : Export or press Alt+E.
  2. Select the required language from the list of Languages displayed.
  3. Select a format from the list of Formats displayed.
  4. By default, the exported file will be stored in C:\Program Files\Tally.ERP 9 for Windows 7 and C:\Tally.ERP 9 for Windows XP operating systems
  5. Press Enter to accept the default Output Filename or type the filename of your choice in order to save the file with a different name.
  6. Press Enter to accept the default Output Sheet Name.
  7. To update the existing file select Yes in Update Existing File.
  8. To format the contents of the file select Yes in Excel (Spreadsheet) formatting.
  9. Select Yes for the Field with Colour, to retain the background colour in the exported file.
And Second:
selecting the ASCII (Comma Delimited) format, the user can export all the reports or data from Tally.ERP 9. The data exported is converted to plain text separated with commas and stored in a file with the extension .txt. This file format is widely used for emailing and used for importing data into another company using Tally.ERP 9
More information please visit this link.
http://www.tallysolutions.com/website/CHM/TallyERP9/Data_Management/Export_Formats.htm
Thanks,
How do I get the image from my laptop out through my sharper image projector?
Depends what inputs you have on the EC-PJ10 or coming out of your laptop but the most common way is via the 15pin VGA connector you will have to configure the output when connected so as to switch the video information from the laptop screen to the 15pin VGA function this is by way of using the F keys.
If there is a video card in the computer can you still use 15 pin as monitor
The 15pin video connector is an OUTPUT to connect to a video monitor to display what the computer is doing.
I need access to manual for the Image Pro 8758. We are getting no picture output from Projector. currently using the component to 15pin VGA wiring. Which is connected to the Computer 2 input terminial on...
Try pushing the source button either on the projector or the remote. It will tell the projector to look for another source. It may currently be set on one of the other sources. If you look up the manufacturer on-line, you should be able to download the manual.
2helpful
My tally version is Tally 7.2 my problum is how to export my tally data in to excel format. In my tally export option only three option's where occuring that are as follows 1. ASCII 2. Html and 3. Xml
Go to 2 Point Html than give the any name of output file (for example sale register.xls) after that you can see your file in exel format.
any problem you may contact me at 09310947557 (Delhi)
Narendra Chaudhary
How to connect samsung pasma tv to pc?model number is PS42B450B1XUM
That does depend on the PC, but I'll assume it's a pretty standard PC.
You ideally need a Male 15Pin VGA cable to Male 15Pin VGA cable. (aka A normal Monitor Cable) The same as you probably have connected between your PC and Monitor.
Your TV has a 15Pin VGA Female socket on the back, this cable plugs into here.
For Sound the TV has what looks like a headphone socket next to the VGA Plug. You need to use a Stereo Jack Plug to Stereo Jack Plug Cable. 3.5mm. This goes from your PC's Audio Line Out (rear of the PC) to the Plug on the rear of the TV. It is usually marked Aux In or PC Sound.
Enjoy, The PC will look great on the Tv.
1helpful
How do i hook my compter to my tv
im assuming here you have a new LCD TV with High Definition
if you have a new LCD TV most of them come with either a HDMI input or a 15pin VGA input , if you computers graphics card doesn't have a HDMI output on the graphics card you can use a male to male VGA cable , they are used on most PC LCD screens if you don't need it , 15pin VGA cables usually have blue plugs and have 15 pins :) or you could go to an electronic store and ask for a male to male VGA cable.
once you get the pc conencted to the tv ,
1. right click on the desktop
2. click properties
3. click on the settings tab
from here you can change the resolution and make the TV look decent.
i hope this helps you :)
23helpful
4answers
How to Export trial Balance from Tally 9.2 version to Excel sheet
you select the trial balace--and press Alt+E or click export---then the export details screen came,
Language: Default(all language)
Format: Excel (spreadsheet)
Output file name: trial bal.xls (any name you select)
Excel (spreadsheet) formating: yes
other details you select and accept the screen. then minimise or close the Tally, you open the tally file name at my computer. at the time you can see the file trialbal.
180helpful
15answers
Export tally data to excel format
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
