Question about Dewalt 7.2-18.0 Volt One Hour Charger
Two quick flashes problem powerline what does that mean exatly
    New Friend:
    Problem Solver:
  • 4 Answers
How do you unsuspend. Mine seems to be stuck in this mode...
Posted on Sep 28, 2015
    Habit-Forming:
  • 188 Answers
From the manual.
Some chargers have a Problem Power Line indicator. When the charger is used with some
portable power sources such as generators or sources that convert DC to AC, the charger may
temporarily suspend operation, flashing the red light with two fast blinks followed by a
pause. This indicates the power source is out of limits.
Posted on Dec 29, 2013
6ya staff
SOURCE:
What does the light in the middle mean because mine wont stay on?
It simply tells you that no other powerline devices detected on the powerline network.
You may refer to this image link.
http://fixya-by-mongkey.webasyst.net/DD/html/scripts/getfolderfile_zoho.php?DL_ID=NDA%3D&ID=9d7fc82bbbc20e37c33bce11d86a0f65&DB_KEY=TVIxOTIx
or this manual link.
ftp://downloads.netgear.com/files/XE102_UM_8Jun07.pdf
I hope this answers your question.
Mongkey
"Understanding explains better..."
Jan 22, 2011 | NetGear Powerline XE102 Ethernet Bridge...
The light flashing is signaling a problem powerline. does this mean i need to replace the charger or can it be fixed?
Could be either the charger OR the battery. Before spendin anything on a replacement try cleaning the battery and charger terminals with a Q-Tip moistened with alcohol. Even a small buildup of dust can cause the fault.
Mar 15, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
What does it mean when the word "HOLD" appears blinking on my dashbord, I believe it has to do with the gears
Yes the HOLD light comes on when the computer detects a malfunction with the transmission....one quick flash of the hold light means a 01 code. six quick flashes would mean a 06 code. 5 long flashes would indicate a 50...6 long flashes would indicate a 60 code. Hope this helps.
Mar 14, 2010 | 1994 Mazda 929
My download speed has been reduced from 20 Mbits to 2 Mbits after having plugged in a set of XE102. Why? Can I do something ? Regards Mogens Villy Møller Copenhagen Denmark
The top speed between the devices is 14 Mb/s, so they will never attain the 20Mb/s speed you had with you router / modem.
Netgear offers this FAQ for Powerline devices:
Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
  • Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or uninterruptable power supplies.
  • Passwords. Powerline products have both a network password, and a device password. A particular device's password, which is not changable, is printed on the Powerline product label. Once you have collected all your Powerline device passwords, use the encryption dialog box, as described on pages 9 and 12 of the XE102 User's Guide, to change the network password. (Without password protection, it is possible, although unlikely, for someone very nearby to access your network.)
  • If you changed the default network password, make sure that all the Powerline products use the same network password.
  • If you've moved a Powerline unit, or disconnected the cables, your other network devices may need about 5 minutes to refresh their information about the Powerline's current status.
  • If you have earlier Powerline products, switch to the encryption used by later products. (Early versions of XA601 and XE602 are known to have compatibility problems with newer models.)
  • To test whether a house's electrical wiring is contributing to Powerline problems, plug units in the same room. Examples of potential problems are:
    • Old fuse boxes.
    • Old wiring that does not meet modern wiring building codes.
  • Swap devices to isolate the problem to a particular Powerline unit.
  • Reset the Powerline adapters to the default settings using the utility.
  • Use all the same Powerline models for best connectivity. Also, software for one model may not work for another model. In particular, remote and advanced features may not work between Powerline manufacturers.
  • Powerline is not directed at businesses, however it may work in a business environment, anyhow. See Assessing Powerline for Business Environments. In some cases noise can be limited by placing line conditioners or surge protectors between the source of the noise, and the Powerline units. (Not between the units.) Consult a professional electrician to evaluate your electricity's noise and to suggest remedies.
Sep 29, 2009 | NetGear XE102 Powerline Ethernet Adapter...
The middle light on my netgear ethernet bridge xe102 wont stay on
-- Xe102 device is simply a plug n play device
-- so if the connection light shut off after some time
-- first hard resett the powerline adapter
-- and after that get the powerline checked
-- If that doesnt work there is no specific configuration
get the adapter replaced ..
Jul 01, 2009 | Powerline Netgear XE102 Ethernet Bridge...
Trouble installing XE102 Powerline
there wasn't actually any problem with the device. For these bridges to work, you need to be on the same phase of the wiring. If the devices are on different phases then they can't communicate. But I still couldn't get the encryption to work. Netgear support doesn't seemed to be bothered with that...they told me to ignore it.
Dec 16, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Can my neighbors or power company intercept my data over my powerline network?
Our Powerline devices have security that will prevent anyone from seeing your Powerline network. Using the utility provided with the device, you can encrypt all data transfers over powerline to 56 bit DES. In addition, the range of the powerline signal is limited, in order to help prevent others from accessing the data stream.
Feb 19, 2006 | Efficient Networks Siemens SpeedStream...
Dewalt 7.2-18.0 Volt One Hour Charger Logo
1,504 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
