Drillbits "burn" what you are drilling when there is too much friction. That is caused by a variety of things...including...lack of lubrication for metal work...and usually a dull drill bit in wood.
If you see no smoke comming from the point of impact...it might be your drill motor..check it out when you are using it...it could be dirty and need a good cleaning...or it could be burning out from excessive or improper usage.
Well it is definitely from the drill not what I am drilling. It cannot be dirty because I have not used it enough to get it dirty.
if the motor is burnt should I stop using it? Is there a way to fix it or should this be looked at by a authorized dealer?
