Posted on Apr 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F5 Error flashing
Our copier just started flashing F5 on it's screen. I looked in the manual and it has nothing about an F5 error. Is there anything I could do to clear the error and get it going again?
Everett Lin
Level 3:
President:
  • Sharp Master 990 Answers
  • Posted on Apr 24, 2009
Everett Lin
Sharp Master
Level 3:
President:
Answers
990
Questions
Helped
434388
Points
3069
Hello sir; The F-5 means the exposure lamp bad, replace it, will take care your problem.
1 Related Answer
Anonymous
  • 132 Answers
  • Posted on Apr 28, 2011
SOURCE: Our copier just started flashing
Hello
The error that you see has got to do with the copy lamp.
Either the control ciruit (inverter) or the the lamp is open circuit
Regards
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
2answers
Hello
Regards
My acer travelmate will not come on it starts up then says the windows did not shut down properly it then goes to start windows normally then nothing else happens is there anything i can do to sort this...
Sounds like a corrupted Hard Disk. The Hard Disk can get errors on the Drive over time... there is a utility in MS to fix this, but you are not getting that far.
If it does ask to Run a Disk Check... let it do so...
If it does not... you need to go to Safe Mode and Run it Manually.
Get to SAFE MODE: Pressing F5 after the System Info Screen appears but before you see Windows Booting. SELECT SAFE MODE in the Text Screen.
Once there... goto My Computer | Right Click C:\ Drive | Left Click Properties | Tools Tab | Click Error Checking... check both boxes. It may want to schedule it.. do so and Reboot.
Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
3helpful
2answers
SHARP AR5320 error F5-02
SHARP AR 5020 error F5-02 pls canu give some tips very helpful its urgent sir
Asharp AL-1631 won't print anything but a mess.
E7 is a few different things. Are there two more numbers flashing after the E7 appears?
F5 has to do with the copy lamp.
It should be looked at by a technician. It needs to be looked at for the E7 issues.
2answers
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 • Ovens
E007 Error message
I found nothing in online manuals, lab tests or anything else. It looks like Canon really wants you to have to contact one of their reps to get more info. Perhaps someone else has one that is familiar with the error. You might also try a Help or Information button that might be on the machine itself. Good luck!
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
