SOURCE: proform treadmill zt 5 runs but display is dead
If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
SOURCE: I B0UGHT AN IFIT INCLINE TREADMILL FROM SEARS IN
This machine is made by Icon Health and Fitness. You can go to www.iconservice.com and use your model number to download free manuals.
SOURCE: My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
