Computers & Internet Logo
Posted on Apr 24, 2009
Laptop won't boot up black screen
My hp pavilion tx 1000 notebook I get a black screen @ start up nothing else, I tried the suggestions @ hp tech, I reset the memory, I pressed the f10 key @ boot up nothing, I removed hard drive, nothing, I removed the a/c adapter and battery, also tried starting it without batt, to drain syst, is it my mother board? how would I know if it's my display monitor
  • Anonymous May 11, 2010
    Have you tried hooking up an external monitor? Or possibly the screen may be shut-off with on of the "function" key combinations? (Fn key plus the screen key)
    If you removed the hard drive and still get nothing it is probably your motherboard. If this is the case you will see nothing on the screen at all. Possibly lights and fan may come on.
Anonymous
Level 1:
  • Contributor 12 Answers
  • Posted on Jul 05, 2009
Anonymous
Contributor
Level 1:
Answers
12
Questions
0
Helped
19101
Points
76
Its *********** board. i found a solution for the smae problem on youtube worked like a charm, http://www.youtube.com/watch?v=ctHTF3oNdxI
2answers
The screen remains black when computer is turned
maybe a hardware problem, on booting the pc, move the screen to every angle to see if there is a connection problem.
If so, then use your warranty if you have one.
I have to turn it on and off for several times just for it to start wroking
If you get just a black screen - all lights on except hard drive light and fan seems to be working, then you are probably experiencing the same GPU (video chip) issues as others. Here is a good read - http://h30434.www3.hp.com/t5/TX-series-notebooks/Familiar-Story-tx2000-lights-and-fan-on-but-black-screen-at-boot/td-p/87361
...and here is the service manual if interested in trying the permanent fix yourself.
Hp tx 1000 black screen please hel
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Hi, I have an HP pavilion tx 1000, it does not boot, it starts off but then freezes in a few seconds.
TRY TO USE ANOTHER RAM TO TESTING.. AND ALSO THE HDD CHANGE.. FOR TESTING FIRST IF WHERE THE EXACT CAUSE OF NOT BOOTNG ANG FREEZING... OR THE DVD ROOM REMOVE IT THEN START THE LAPTOP
1helpful
HP Pavilion tx 1000 Won't Start-Up
as a last resort,(or first, when I have laptop boot problems, is to unplug battery and power, and hold power button down for about 30 seconds, release, plug in and test.This Solves alot of laptop boot problems regardless of manufacturer. Hope this helps, if so thanks for any ratings
2answers
HP Pavilion tx 1000 wont start
My HP tx1005au laptop has the same problem after using it for 1 year 7 months. It has power, fan is blowing, but monitor is black. If you keep on trying to start it, sometimes up to fifteen tries, it will suddenly start as if nothing has happened. It is driving me nuts. Hope someone could enlighten us as to what is wrong with this.
Grand Canyon Tech
Grand Canyon Tech
