Question about Sony BRAVIA KDL-40V3000 Television
Common problems of bravia bx350 - Sony BRAVIA KDL-40V3000 Television
Bravia klv 32ex300. Runs for a few minutes, then turns off. Restarts twice then turns off and won't restart. What's wrong?
most common problem is main filter cap aster which is in power board if find defective please change but if its ok then replace main board because system ic internally leaking
Aug 29, 2015 | Sony Televison & Video
Usb cant paly movies in tv bx350
your owners manual will tell you what formats , audio and video codecs will be acceptable to the TV. Your usb memory stick file (avi, mp4,mkv, may play on your pc but not on the TV. Find a video file convertor program to fix your issue
Apr 05, 2014 | Emerson Televison & Video
Sony 32cx520 bravia screen or color problem .. ask lng po kung pano ... tnx
there is a problem in interface between panel & main system board through lvds cable there are six comman mode coiles between the lvds jack from system ic these common mode coils are opened & this problem is occer please changes these coiles which are very near to lvds jack after replacing your set problem is ok.
Jan 12, 2014 | Sony 32CX520 BRAVIA Multisystem LCD TV for...
SONY Bravia NX710 TV Screen or Color Problem..
now a days most common problem is this in Sony led please replace common mode coils which are very near to Lvds jack these collies are situated between system ic & led tcon & are responcible for communication between these two
My bravia kdl52nx800 shuts down right after turning it on. flashing 6 times
Very common problem the 6 blinks is indicating an issue with the Inverter. Replacing the inverter should solve the issue. You should be able to get the Inverter from www.tvcircuitboards.com
Oct 27, 2012 | Sony KDL52NX800 52 inch BRAVIA 1080p LED...
I have a Sony Bravia 52 inch HDTV that has a line down the middle of the picture in some shows, particularly when action is panning across a scene. Is this a common problem?
Check with a different CD or a different channel. Sometimes some,
secret codes are displayed to find the pirated CD. Any how check in different program channels. This is not TV problem.
If you have DVD try a similar action movies in CD and play to satisfy!
Aug 21, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Good day, I am all of the sudden getting double vision and a white line across the screen, it eventually goes away, not sure if it may be my directtv reciver?
This is a common problem for Sony BRAVIA KDL-52W4100. You can reconnect the LVDS cable to the Main board, the location # is CN4701.
Apr 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
Oct 19, 2009 | Sony BRAVIA KDL-46V3000 Television
I have a 4 month old sony bravia 1080 120mhz Sony
Not common but electronics are electronics , we can have failures right out of the box. Generally Sony is reliable and I must say that you should not have to worry about cost , Is it not under warranty - its only 4 months old !!
May 13, 2009 | Sony BRAVIA KDL-40V3000 Television
Cut out
I had the same problem with this model, seems to be a common problem across much of the recent sony range. For me the problem stopped when I unplugged the external aerial (not much use if you want to use freeview, but maybe some indicator of source of the prob ?)
Jul 18, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
