Will not spin
Whirlpool LSB6300PW2 will not spin, fills, agitates and drains OK, Pump OK, Coupler looks OK, Clutch inside was misaligned when I looked at it and it contained black powdery residue Plastic part for clutch looks Ok. It just froze on spin, maybe the brakes locked up. Wash included packs with draw sstrings/ropes which got wrapped up against the agitator spindle and finally broke. Made a helluva racket before it stopped spinning. What's wrong? Is it the clutch? Brake? Or transmission?
  • mclaw507 Apr 26, 2009
    BIG SURPRISE!!! Disassembled entire washing machine. The clutch was out of alignment/slanted up by about 20-25 degrees. One of the brake shoes was out of alignment too, again by about 20-25 degees. I guess when the clutch couldn't engage, then the brake was locked up. Anyway, when I removed the porcelain tub, I discovered a small (1/2 to 3/4 inch) round, black plastic handle/knob from a backpack that was put in the washer by mistake. Made quite a racket. Apparently, it acted like a ball bearing and moved everything by about 1/2 to 3/4 inch. Put everything back together and it works like a charm. No new parts needed. Thanks.
  • 43 Answers
Could be clutch but I would check your lid switch first.
Posted on Apr 25, 2009
  • Anonymous Apr 26, 2009
    If your transmission clutch hub is spinning Your transmission is good. Turn the brake clockwise to relieve tension if it doesn't spin fairly easy your brake basket drive is bad . Could have been caused by the bindings. Hope this helps.
6ya staff
SOURCE:
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
My kenmore washer will wash okay, drain okay, but when it's supposed to spin, only the agitator spins; the tub stays stationary. Kenmore topload washer, model # 110.26742503
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026742503/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Three possibilities: since you can hear the motor (Ranging from easiest to messiest) None of the suggestions are very expensive.
Actually, the agitator isn't supposed to spin. See the section of the Whirlpool manual on the Agitate Cams also.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams and spin gear.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit or spin gear, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
COUPLER OR CLUTCH:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities: since it will spin. None of the suggestions are very expensive.
spinning.
Nov 05, 2010 | Kenmore Washing Machines
The machine does not spin. It drains and fills well but does not spin at all through out the washing cycle.
spinning.
Oct 10, 2010 | Washing Machines
Will fill, drain, and agitate but will not spin. When in spin cycle just hear a loud noise.
spinning.
damaged.
motor aside.
Aug 14, 2010 | Kenmore 22422 Top Load Washer
The water will come on at diferent times during the cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
If the agitator and shaft are OK, the problem may be in the Motor Coupler:
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
spinning.
coupler.
If the agitators are OK, and the Motor coupler isn't damaged, the problem points to a set of and/or spring in the transmission. ($15.00 items)
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
Also see the Whirlpool parts list for their commercial washers although the consumer models use the same transmission and parts.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Apr 15, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 110.24642300, it fills, it washes, it
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24642300&pathTaken=partSearch
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
It's also possible that the Neutral Drain Assembly in the transmission is broken:
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
Mar 30, 2010 | Kenmore Washing Machines
Kenmore Washer Model 110.26712693 will not agitate. The machine will fill, drain, and cycle, but will NOT agitate.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26712693&pathTaken=partSearch
I assume that it will neither agitate NOR spin.
If that is the case, the problem points to the motor Coupler.
If the Motor Coupler is fine, the problem may point to either the agitators themselves or the transmission.
If the agitator and shaft are OK, the problem may be in the transmission.
If the machine WILL spin but WON'T agitate, the problem points to the Agitate Spring in the transmission.
See the following Whirlpool / Kenmore service manuals for how the transmission works and what the spring and Agitate Cams do.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
Also see the Whirlpool Parts List for top load, commercial washers although the consumer models use the same transmission.
Mar 26, 2010 | Kenmore Washing Machines
Kenmore 110.23832100 post rinse cycle spin problems
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23832100
See the Whirlpool service manual for these washers.
Sometime spinning points to a few places.
First, Kenmore top load washers use a motor coupler to transmit power from the motor to the transmission for agitating and spinning. If the coupler is worn or damaged (the prongs on the motor or transmission shafts are broken) the machine may agitate but may not spin.
Second. These washers use a clutch to transmit power to the tub for spinning. If the clutch is worn, it may not be able to transmit all of the power from the transmission.
Third. These washers are whats called Top load, Direct Drive Neutral Drain. This means that when the washer goes into spin mode, the "neutral drain assembly" has a built in mechanical timer that allows most of the water to drain and then begins the spin cycle.
If the cams in the neutral drain assembly are broken or, as we found onours, a spring on one of the cams is broken, the machine won't spinwithout help.
Forth: These washers use a spin tube, driven by the clutch and connected to the tub with a "basket drive block" If the tabs on top of the spin tube have broken off or aren't inside the slots in the drive block, the tub may not spin.
All of the diagnostics start with pulling the cabinet.
See the following:
With the transmission out you have access to the motor coupler and clutch. Check both before proceeding.
If the motor coupler and clutch look OK, I'd pull the tub and spin tube and check the tabs on the spin tube and drive block.
If all else appears OK, the problem points to the neutral drain assembly.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
Oct 27, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool super capacity Lsq9549lw0 has trouble spinning on its own.
If the washer does fine thru the agitation cycle (the washing), that means the motor is OK and the coupler is OK.  It would not agitate unless both are OK.  (and don't listen if anyone tells you the lid switch is bad -- machine would not fill & go thru wash cyle). The spin is another matter.  There is a separate tube for spinning the basket.  There is a drive  block at top of the tube (that sometimes fails)  and there is a separate cluch mechanism below, under the tub.  Those places is where you should look.
May 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Nov 05, 2007 | GE WSM2700D Top Load Stacked Washer /...
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
