SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
SOURCE: Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
SOURCE: NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
