Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
A
Alfred Renteria Posted on Oct 17, 2013
Blinging green light - Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Dennis Hogsett
Level 1:
  • Contributor 45 Answers
  • Posted on Oct 17, 2013
Dennis Hogsett
Contributor
Level 1:
Answers
45
Questions
Helped
12761
Points
65
You need to change your backlight. Your manual should tell you how
Won't turn on
main board issue see link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Green light is continuesly bling but the projector is not given the display
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Wholesale - 2014 Luxury Crystal Ball Gown Bling Bling Wedding Dresses With Puffy Tulle Skirt A-Line Sweetheart Strapless Bridal Vestidos Dhyz 01
You need to follow this up through
http://www.dhgate.com/store/product/2014-luxury-crystal-ball-gown-bling-bling/179891720.html#se1-3-1'4015850791
Front penal 1 and 2 green lights blinging
You WILL get blinking lights. It is either disk activity .. the computer is doing something (even if you are not using it..) ..
If your computer works fine, then all is fine. Lights on computers ... show when it is powering up, loading/downloading .. active. Normal..
Do you have an actual problem?
WHEN ITURN MY 52 INCH PROJECTION TV THE GREEN LIGHT BLINGS TWICE AND SHUTS OFF AND I GET NO SOUND
you have a high voltage flyback transformer that probly went bad I have seen this problem before and that is the problem most of the time it is not a easy fix but depending on how old the tv is it is worth fixing! You need to call a shop and have them come out and fix it.
1helpful
Mitsubishi ws-55613 green light blings rapidly and TV will not come on.
The DM module has bad capacitors in it and these will need to be replaced, or the DM module replaced.(about 85% of the time, the caps WILL fix them though...) A good shop should be able to rebulid your module for about 300-400 in the home.
My Panasonic KX-T7730 led green always bling, and I do not use any more, the other side SP-Phone doesn't work, what do I do
go in contact with Panasonic.....and tell them ur problem....
Panasonic customer help line and support
Blinking green light of death
First thing you want to try is plug it directly into the wall to see if your surge protector is not allowing the proper voltage. If that works. Go buy a UPS.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
