SOURCE: Hi, I have a Samsung Galaxy Tab Tablet and would
It can't be done. There are technical along with legal issues.
SOURCE: Hi, i have Galaxy Tab model
Install these drivers http://firon.net/xda/Samsung_Mobile_Driver_V1.3.800_For_SPH-d700_Epic_4G.zip for windows 32bit
this should fix your problem
SOURCE: I am using samsung galaxy
Being a NEW phone please do not attempt to open the set or trials as your set is covered under warranty. The best you can do is to remove the battery and reset to see if the phone works fine . if not get the free warranty support from the service dealer.
SOURCE: every time I open my galaxy tab. I can not access
touch and hold on pressing the home key until a task manager note will pop out end the recent tasks or uninstall the programs that u suspect making problems. my galaxy was having problems with viber and what's up communication apps i uninstalled them and the problem was solved automatically
SOURCE: My samsung Galaxy Tab GT
Somehow this is related to the SD card. I had replaced the original 2 GB SD card with 8 GB one and it was working fine. I used to use the flash as a torch by using the record function with flash and then pause which leaves the flash ON to be used as torchlight. But then it broke down displaying Camera failed. I did lots of troubleshooting but it didnt work, finally I inserted the original SD card back and the cam started working. Try this:Switch Cam Storage to SD card then remove the SD card from the cell and reboot the cell without the card. let the cell work for few mins(30 to 60mins)without the SD card. Now insert the SD card and reboot the cell. wait for few mins and check. Replacing the SD card from another cell may also work.Good luck
