I have a Mitsubishi 62" LCD projection TV. Just recently the device buttons do not work on the front panel or remote. When I try to look at devices the TV will shut off within 30 seconds. I can watch DirecTV with no problem. when I press the arrow up (device button) on remote the screen goes blue and shuts off. Could this be a remote problem. Also when I try to set up the directv remote to operate TV and hit the TV Input the TV will shut off.
Thanks a alot this worked for my device buttons not working and the tv shutting off. THANK YOU VERY MUCH!!!
Could have a stuck button or a corrupt e-prom, but lets try kicking this set in the head, Now these reset codes are model dependent so this code will not work for every set out there but this reset is for the WD-62525. with the set on and with the original TV remote hit the keys in this sequence, MENU-2-4-7-0 this will bring up a service menu, the cruiser should already be on "Initialize" so simply hit enter. this will reset the TV to factory defaults and may fix your problem
We have the same problem, we turn the tv off at night and the next day it is set to Ant and we can't get a picture. If we press device buttons or menu buttons on the remote the tv shuts off in 30 sec.
The remote control does not work and the menu screen will pop up and stay on for a few minutes and then goes away. After a while it stops doing it but the remote still does not work. We have tried unplugging the TV and hitting system reset. It worked a couple of times but does not work any more. Can you help?
