Linksys Wireless-G WRT54GS Router (e125894) Logo
A
Anonymous Posted on Oct 18, 2013
New password for 192.168.64.1 router - Linksys Wireless-G WRT54GS Router (e125894)
Hi i want to change my password on my Huawei router. how do i reset it . Thanks
To reset the password on your Huawei router, you can follow these general steps:
  1. Access the Router Settings:
    • Connect your computer or mobile device to the Huawei router via Wi-Fi or an Ethernet cable.
    • Open a web browser and enter the default IP address of the router in the address bar. The default IP address for Huawei routers is often "192.168.1.1" or "192.168.0.1". If these addresses don't work, you can check the router's documentation or look for the default IP address on the router itself.
    • Press Enter to access the router's login page.
  2. Log in to the Router's Configuration Page:
    • On the login page, enter the username and password. The default login credentials are usually provided on the router or in the documentation. Common default usernames and passwords for Huawei routers are "admin" for both the username and password fields.
    • Click on the Login or Sign In button to proceed.
  3. Navigate to the Password Settings:
    • Once you are logged in, find the settings section related to Wi-Fi, Wireless, or Security.
    • Look for an option named "Password," "WPA Key," or "Pre-Shared Key" to change the Wi-Fi password.
    • If you want to change the router's administration password (used to access the router's settings page), look for an option like "System," "Administration," or "Management" settings.
  4. Change the Password:
    • Enter your desired new password in the appropriate field.
    • Make sure to choose a strong and secure password that includes a combination of letters, numbers, and special characters.
    • Some routers may require you to re-enter the new password to confirm it.
  5. Save the Changes:
    • After entering the new password, look for a "Save," "Apply," or "Submit" button to save the changes.
    • Click on the appropriate button to save the new password.
  6. Test the New Password:
    • Disconnect any devices currently connected to the Wi-Fi network.
    • Reconnect the devices to the Wi-Fi network using the new password to ensure it is working correctly.
99 s 10
Please reset your router and enter gain using the default username and password.
The default username and password for Netgear routers are admin and 1234 respectively.
1. Open your web browser and type in your router's IP address. The default IP address for Netgear routers is http://192.168.2.1.
2. Enter your username and password once prompted by your web browser. The default username and password for Netgear routers are admin and 1234 respectively.
3. Select "Set Password" from the left hand navigation menu on the router's manager menu.
4. Type in the old password, which should be 1234 if it is set to default and then type your new password twice.
5. Click "Apply" and the new password will take effect immediately.
Password forgotten need to aqccess new device
what you need is the network password which you can get by accessing the router firmware page.........and you have forgotten the router password as well then reset the router and crete a new router password and enter the router to get network password
Change password in my router
Log in to the router's administrative console through a Web browser using the current password and username.
In the router's administrative console, navigate to the appropriate administration / security section where the password setting can be changed. In this example, the Administration tab at the top of the screen contains the Linksys router's password setting.
Choose a suitable password based on the standard guidelines for strong password security. Enter the new password in the Password box, and re-enter the same password a second time in the space provided. Entering the password a second time ensures you did not accidentally type in the wrong password the first time.
The password change is not applied on the router until you save or confirm the change. In this example, click the Save Settings button at the bottom of the page to have the new password take effect. You will see a confirmation window appear briefly to confirm the password change was made successfully. The new password takes effect immediately; rebooting the router is not required.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
How can I change my password
Enter the account name and password to open the router setup utility.
Navigate through the setup utility until you find the screen that will let you change the password. You will need to enter the old password to change it.
Decide on a new password that has good security to a hacker. The best password is more than 8 characters and uses both lower case and upper case letters and numbers. Some will allow you to use special characters also. Do not make the password anything that can be found in a dictionary or any date of significance.
Enter the old password in the change password page of the router. When prompted then enter the new password. You will be asked to enter it twice to confirm that the correct password is entered.
Immediately, record the new password in some secure location that you can find if you forget it.
Confirm the password change on the router page and log off the router. To check the information and that the router has been setup correctly with the new password, open the router address in the browser again and login with the new information. If you are able to login, you have successfully changed the password.
2answers
D-Link wireless router forgot password how may I recover or assign a new one
A wireless router password wont be recovered unless you still have the password you can enter or if the router is unmanaged without an admin password.
another option would be resetting your router to be able to get through the router and assign a new password.
here's how: you need to directly connect your computer or laptop wired going to your router not using a wireless one. then reset, make a new network configuration and put your admin password later. dont forget to backup your router config. in a folder together with your password so the nextime you forgot any thing or change anything. just look back to your folder where you put your backup config. and password.
6helpful
2answers
To change password
Open new internet explorer tab and type
http://192.168.1.1/ (If it doesn' ask for username and password try below address)
http://www.routerlogin.net
Ckeck if it asks for username and password
If ask give
username : admin
password : password
Now will be navigated to router configuration area
Now our next job is to navigate to wireless settings ( left side)
security option click on wpa/wpa2
now on passphrase enter new password
click on save button to save the settings
That'a all
Note: all devices that is connected to router via wireless will loose the connection . Now you have reconnect it using the new password
Thanks
Vote me if you are satisfied with my answer
How do i change my router password
Please just follow the steps to change your router's password.
1. Open your Internet browser, type the address of the router into the URL address bar, and open it. The address is typically in the form of 192.168.X.X. This is the local network address.
2. Enter the account name and password to open the router setup utility.
3. Navigate through the setup utility until you find the screen that will let you change the password. You will need to enter the old password to change it.
4. Decide on a new password that has good security to a hacker. The best password is more than 8 characters and uses both lower case and upper case letters and numbers. Some will allow you to use special characters also. Do not make the password anything that can be found in a dictionary or any date of significance.
5. Enter the old password in the change password page of the router. When prompted then enter the new password. You will be asked to enter it twice to confirm that the correct password is entered.
6. Immediately, record the new password in some secure location that you can find if you forget it.
7. Confirm the password change on the router page and log off the router. To check the information and that the router has been setup correctly with the new password, open the router address in the browser again and log in with the new information. If you are able to log in, you have successfully changed the password.
Thanks.
Have a great day.
Re: Password change
Hi, The below steps are assuming that your router is at default settings, you are connected to your router (preferably by LAN), you can ping your router. 1. Open a browser (IE or Mozilla); 2. in the address bar type "192.168.1.1", enter; 3. on both username and password type ?admin?, OK; 4. in Quick Setup, select Step 1, Next; 5. in Password type your "New Password"; 6. in Verify Password type again your "New Password", Exit; 7. Save Settings; and 8. restart router. All other configurations should remain as-is. Hope this be of some help/idea. Post back how things turned out or should you need additional information. Good luck and kind regards.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
