The first thing that comes to mind is that either the charger or the battery is faulty. You can check whether the battery is retaining its charge properly or if it drains out quickly.
The Kocaso NB1016 specification states that it uses ...
"Power Device Type:AC, DC can DC can car charger". So you can test whether it can be charged from a car battery. If so, then your charger is at fault. If all else fails you'll have to contact Kocaso support for a software/firmware upgrade.
First you need an ISP so you can connect your router via Ethernet.The if your ISP give you a router the you can connect your to the ISP router via Ethernet if you like so you can have more signal range all over.
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
