My tablet was low on charge so clicked battery use , instead of continue, then my tablet turned itself off. it wont turn on and it wont charge. what should I do!
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
Try pressing SLEEP/WAKE button and HOME button *at the same time* to force it restart for 2 or 3 times and see if it can turn on. Sometime it's just turn off by itself (happens more frequently for me esp when the battery is low) and we have to force it to start again.
Hi
It will not charge. Are you sure that the battery is OK?
Do you charge the tablet with electricity or via USB?
You have checked the cord and wire into the the plug and the plug itself. Is it possible for you to borrow a charger to find out if it is the battery that is not working.
All the best
Kolbrun
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
