Maytag top load washer stopped mid cycle and is full of water. the washer will not restart how do i drain the water out of the machine?
Top Strongest Brass Fitting Flexible Expanding Garden Hose on the Planet with Solid Brass Ends Double Latex Core Extra Strength Fabric 9' Function Spray Gun Chornic Top Strongest Brass Fitting Flexible Expanding Garden Hose on the...
Howdy IBAT125,
It sounds like a wet/dry shopvac is what you need. You can buy or rent one at The Home Depot. I suppose you will need to either call a repairman or look at buying a new washing machine too.
Either way, Have a Merry ChristmasCoach Dave at The Home Depothttp://community.homedepot.com/
I'm no expert but have been experiencing a semi-similar problem. I pressed the "pause/start" button, then changed the dial to "drain" and pressed "start". Worked for me. Good luck.
I take it that you have tried rotating the cycle knob slowly through the point at the end of the wash cycle to the rinse cycle? On many machines, this will trigger the pump to drain the tub. Yet I am guessing that you have already tried that.
You could try running a garden hose from the machine along the floor and then outdoors. Next, take the end of the garden hose and place it into the top of the machine so that the end of the garden hose goes to the bottom of the tub. Feed in another five feet of garden hose into the machine so that this five feet is below the water level. Now, hold the palm of your hand over the end of the garden hose at the bottom of the machine and while doing this, pull out the extra five feet of garden hose and then remove your hand from the end of the garden hose. This should have "primed" the end of the garden hose with water so that the water will get sucked out of the machine and flow through the garden hose to the outdoors.
If this doesn't work, then you will need another person to **** on the other end of the garden hose in order to get the water to start flowing through the garden hose.
