Frigidaire Affinity ATF7000E Front Load Washer Logo
G
Govinda Pamudurthi Posted on Feb 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I recently purchased a 6 year old condo and
Hi, I recently purchased a 6 year old condo and along with it the Frigidaire Affinity front load washer. As soon as I moved into my condo, I noticed a petrol like smell coming out of the washer. I really appreciate if anyone could let me know as to how I could get rid of this smell.
vince
Level 3:
  • Frigidaire Master 2,530 Answers
  • Posted on Feb 26, 2018
 vince
Frigidaire Master
Level 3:
Answers
2530
Questions
0
Helped
749002
Points
8845
The result of cool water temperatures and milder detergents, is a buildup of oil and grease in the machine, which produces oily smells in the laundry. Grease and oil can take many forms, ranging from automotive lubricants to greasy foods to oily toiletry items, and, over a period of time, these oils can accumulate and become trapped in various parts of the machine, particularly in the door seal of front-loading machines.
Run an empty cycle with HOT water and a detergent that contains bleach to remove grease and oil from the appliance. However, be sure to use bleach designed specifically for laundry, as opposed to using regular bleach. ie OxyClean. and or a cup of vinegar.
Best to you.
1 Related Answer
Coldcut
Karl Whisenand
  • 1554 Answers
  • Posted on Feb 14, 2008
SOURCE: Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
My Frigidaire Affinity ATF6000FS1 front loader will drain and function properly until it gets to the final spin. it shuts off when there is about 7 minutes left on the timer. I have tried small loads...
It's the timer control, not the motor or filter. Try a different setting. You should also be able to find more information on the manufacturers website, along with a manual and possibly a diagram. Also You Tube is a good place to find out more on how to repair it.
2answers
2helpful
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
3helpful
Frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
