Samsung DV328AE Electric Dryer Logo
y
yesenia Posted on Oct 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does do on the Samsung dryer mean? - Samsung DV328AE Electric Dryer
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on Oct 31, 2013
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146067
Points
960
Samsung Laundry Dryer which is almost new. What does code 'dn' or 'ND' mean on a dryer?
Question edited for clarity. The code is 'Nd', or 'dn'? Neither seem to exist
https://applianceexpresstx.com/dryer-repair/samsung-dryer-error-codes-explained/
'D' codes
Error codes: dC, dE, dF, do, d0, 1 DC, and 1 dF
These error codes indicate a problem with the door, most commonly the door latch or the sensors. When these codes appear, it generally means you need to check your door to see if it closes properly.
More here
https://www.thespruce.com/troubleshooting-samsung-dryer-error-codes-2147296
https://www.google.com/search?q=Samsung+Laundry+Dryer+code+dn%2C+code+nd
My samsung dryer is showing an error code of "OT" what does this mean and how can i fix it?
that code means you have a bad thermistor.if you send the model number whoever helps you can look your dryer up,open the door,look around the opening where you put the clothes in and you'll see a tag with model and serial just need the full model number
1helpful
What does blinking dryer light mean?
If it is not heating check your element and or tstats
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Where is temp sensor in Samsung front loader dryer
DO U MEAN MOISTER SENSOR OR CYCLING TYHERMOSTAT
What does E3 mean on my Samsung dryer
For most Samsung dryers, an E3 error could mean that the dryer tub is too heavy, the vent is clogged, the thermistor is faulty, the control unit is faulty, or that there is a loose wire at the main control unit.
If you were drying a very heavy item or too many articles, try a smaller load. Check the dryer vent to make sure that it isn't blocked or clogged with lint. (I've seen the flap on a vent shift and fail to swivel properly.) Next unplug the dryer and pull it forward. Remove the back from the top (control area) and check that the wiring harnesses are fully seated. You may want to check for corrosion or damaged wires. Next check the resistance of the thermistor (mounted on the blower wheel). (Assuming a room temperature environment, the resistance should be ~6 kilo ohms.) If the thermistor is faulty, it needs to be replaced. If the above steps don't solve the problem, then the control unit needs to be replaced. http://www.searspartsdirect.com/samsung-dryer-Parts/Model-dv665jwxaa0000/1482/0151200/50039961/00001.html has the parts breakdown and many parts are available.
If the dryer is still under warranty, contact Samsung for the repair. I hope this helps.
What does D6 mean on the samsung dryer
i would unplug the dryer for at least a minute and plug it back in and see if it resets it, I am assuming a D6 means a control board, if you unplug the dryer and move it away from the wall, remove the back top panel and look in the right corner from the back of it there should be a manual there. May be a stuck button, run your fingers over all the buttons, I hope this has helped Tim
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
