Hi, I have a Samsung D900 which connects to a Jabra bluetooth headset fine. It rings in my ear, answers calls, hangs them up - the lot. However, the phone does not seem to be sending any other audio through (voice). I've paired the headset with another D900 - it works fine, so it's definately my phone (a setting perhaps?). Can anyone help, PLEASE! Thanks, Nickleback.
hi i m not able to connect jabra bt135 to my cel samsung d900
please help me what setting and how to connect it.hi i m not able to connect jabra bt135 to my cel samsung d900
You can't post conmments that contain an email address.
default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step. http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
You will need to pair it with your phone. first make sure the headset is off, then put the headset in pairing mode by pressing and holding the answer/end button until a solid blue light appears. then you will need to goto your cell phones bluetooth menu, turn your bluetooth on, then in your bluetooth menu you will need to add a new device or discover a new device depending on the type of cell phone you have. Your phone should find the jabra ear piece if it's in range of your cell phone and will ask if you want to pair with the device, after accepting confirm with the pin of 4 zero's.
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at [email protected]
i HAVE BLOOTOTH HEADSET ON ONE HEAR, BUT I DO NOT KNOW HOW TO CONECT HIM ON MY D900i, WHAT SETTING WHAT I SHOULD DO
PLEASE
