My phone is permenantly stuck on a white screen. THe white screen has been on and off my phone since a month after buying and now i can not get the white screen to go away.
SOURCE: zte score stuck on muve music screen loop
Hey i've been workin on these ZTE phone and i guess all u need to do is a reset. But the only problem is u will lose all ur data. all u gotta do is First power off the handset, press the Camera key + Power on key +Down volume key together at the same time.
when restart the handset,When display "ZTE", press the Menu key at the bottom of the screen;
Choose "Wipe data/factory reset" through volume key
Press "Camera" key to confirm the above item
Choose "YES...delete all user data"
Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Now once its done ur phone will automatically configure all the factory setup and should work fine,
Testimonial: "thank you.....its only been locked up for 8 months......that was too easy....I always over think things.......thanks again "
