Hi, last night when i pressed the power on button on the remote control, the standby light went from red to amber then back to red (standby) mode again, even manually pressing the buttons does not help, i have had the back off to check fuses but they are ok, still same problem no picture or sound just a click noise then silence. any suggestions please, thanks!
Good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
No solution, yet... our tv is under warranty, and this is the 2nd time we are going to have to have the SAME problem repaired, and they replaced the whole "INSIDE" the first time!!! so, same problem, 2 different panels, must mean somethings going on, you crappy Sony, you! *shaking fist*
Same here
i have same problem
Our tv is doing the same thing lots of cracking from the back of the set. Few times before it died.
Thing just died. same trouble.
Exactly the same problem - TV is stuck in standby mode. Clicking but doesn't turn on, just goes momentarily to green, then amber then back to red (standby)...
my tv will not some on it flashes green for a couple of seconds and then the red stand by light comes on. Two days ago I tried it again and it actually came on but after I turned it off it has not come back on sense. I can't find my receipt and even if I could it's been a little less than 6 months since I purchased it so the warranty will not pay for it. Does anyone know what is going on with these tv's?
This sounds like a common fault with the LG 50PX4D yet my set is only 2.5 years old. What have you lot done to rectify this problem?
no power on supply no picture, just went off last night
