Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
A
Anonymous Posted on Oct 20, 2013
Technika ta 13 instruction manual - Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack
I NEED AN LG INSTRUCTION MANUAL FOR MODEL 42PC7RVH-TA. I NEED TO TUNE MY TV
LG 42PC7RVH-TA
Hello Joyce,
Service manual site (below)
Personally I'd try talking with the shopjimmy.com folks
"tune" has such an ominous sound when talking of
Plasma sets...
42PC7RVH-TA
Download lg 42pc7rvh 42pc7rvh ta plasma tv service manual
1helpful
Ovens technika B90MTDISS instruction manual
www.technika.com.au/contact
Jun 13, 2014 • Ovens
Instructions for Technika model TA-716
http://www.urbooklibrary.com/signup?prod=101&ref=4975711&q=DOC+Technika+TA716+walkie+talkie+pdf&system_controller=rotator&system_action=site&sf=search&sfv=27
I wish to obtain Instructions manual for Technika Micro HiFi MC208
There is no manual can be found to this device by net.
1helpful
NEED CODE FOR BRAVO 13-1N ONE REMOTE CONTROL FOR A TECHNIKA TV
Try these codes
0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
1helpful
I would like a manual for a technika TA-716walkie talkie
Tesco does not list operating manuals on their web site, so I suggest that you contact them directly by following this link:
http://direct.tesco.com/help/contactus.aspx
They should be able to provide you with the needed manual.
Bill B
16helpful
3answers
Instructions on how to change channels on TECHNIKA MODEL TA-13
Basic Instructions for Technika Model TA-13
On this model there are 7 buttons:
Left to Right these are:
PTT, Push to talk on lh side as screen faces you.
Power/Menu
Scan
Call
Down
Up
Torch Light (on rh side)
Assuming you have used the power button to turn on the radio, the default channel after installing the batteries is 1 or else the last channel to be used.
Press the power/menu button once-briefly, (the current channel will flash for about 10 seconds.) Then use the Up and Down arrows to change channel. Wait for the remaining few seconds and the radio will return to normal operation.
Press the menu button twice, the letter H or L will appear and can be altered by the Up and Down keys to change the power level of the radio. I think this is transmit power which may help you avoid infuriating local taxi companies. Switch back to High power when you're about to go out for the night and need a ride.
Press the menu button three times. This will turn off Squelch control and make a terrible din. Not terribly useful unless you want to pick up a really weak signal (or find out where the taxi driver has taken your neighbour.)
An easy way of finding a channel is to press and hold the Scan button and then the device will rotate through the available channels looking for a signal. When someone transmits, the scan will pause and you can capture it by pressing the PTT button for a second or two. I have found this helpful in pairing my radios with other sets, or picking out channels that work with friend's radios.
Finally, Volume control is really simple, just up and down when not in any other mode.
I had the instructions, which I think included a mention of all available channels I'll scan and post them if ever I find them. hope this part helps though.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
